Doku: Gmoccapy jog increment pins names
- RotarySMP
- Thank you received: 595
02 Dec 2020 21:24 #190906
by RotarySMP
Doku: Gmoccapy jog increment pins names was created by RotarySMP
Hi Norbert,
There is a small error in the gmoccapy doku... on my machine these pins :
... are gmoccapy.jog.jog-inc-x
I like this interface more and more, as I use it. Brilliant york you did on it.
Mark
5.5. Jog Increment Hal Pins
The jog increments are selectable through hal pins, so a select hardware switch can be used to select the increment to use. There will be a maximum of 10 hal pin for the increments given in the INI File, if you give more increments in your INI File, they will be not reachable from the GUI as they will not be displayed.
If you have 6 increments in your hal you will get 7 pins:
gmoccapy.jog-inc-0
Mark
- newbynobi
- Thank you received: 394
02 Dec 2020 21:39 #190907
by newbynobi
Replied by newbynobi on topic Doku: Gmoccapy jog increment pins names
Thanks for the hint, I will check that one, I thought I did correct that one. May be you have the older docu?
Norbert
Norbert
- RotarySMP
03 Dec 2020 07:29 #190940
by RotarySMP
Replied by RotarySMP on topic Doku: Gmoccapy jog increment pins names
Hi Norbert,
I googled gmoccapy, and the first link which comes up is dated "Last updated 2020-08-21 06:34:58 MDT"
This still has the single jog.
Mark
Mark
- Thank you received: 4150
03 Dec 2020 12:49 #190962
I have been caught so many times googling up obsolete documentation, I always go to the main docs page and find what I want from the menus.
I might use google for gcode or mcode syntax but thats it.
Replied by rodw on topic Doku: Gmoccapy jog increment pins names
Hi Norbert,
Mark
- RotarySMP
03 Dec 2020 13:14 #190963
by RotarySMP
Going in through the doc top level and then to 2.8 ( or 2.9) returns the corrected versions. Sorry. I didn't realise that the Docu is completely rereleased wit each version release. Thanks.
Mark
Mark
Moderators: newbynobi, HansU
Time to create page: 0.095 seconds
