Solved : Setup Basic Z Touch Off
- AlexDoran
04 Dec 2020 07:01 #191023
by AlexDoran
Setup Basic Z Touch Off was created by AlexDoran
Hi there, i want setup a basic Z Touch off button in my gmoccapy GUI. I have read the documentation 'on the wiki but i dont want to configure it how the wiki suggests, where you have a fixed Probe location and have to set the workpiece height.
Is there a way to to just have a simple MDI / Macro button and probe at the current location to set Z Height? I tried following a few other tutorials but it seems they dont work for gmoccapy.
- JohnnyCNC
- Thank you received: 115
04 Dec 2020 08:12 #191028
by JohnnyCNC
Replied by JohnnyCNC on topic Setup Basic Z Touch Off
You should be able to do that. I was using Axis when I built this but is should work for you also. I just set the touch-plate on top of the stock and touch off by pushing a button on my touch-plate. Pushing the button causes the execution of this gcode.
In my .ini file
[HALUI]
MDI_COMMAND=o100 call
In my pyvcp-panel.xml. I used this before I had the physical button.
<?xml version='1.0' encoding='UTF-8'?>
<pyvcp>
Include your PyVCP panel here.
The contents of this file will not be overwritten when you run stepconf again.
<button>
<halpin>"oTouchPlateProbeButton"</halpin>
<text>"Touch Off Z"</text>
<font>('fixed',10)</font>
</button>
</pyvcp>
See post #107650 for a picture of my touch-plate.
<pre>
o100 sub
G20
( Set current Z position to 0 so that we will always be moving down )
G10 L20 P0 Z0
( Probe to Z-.5 at F2 [Uses machine units, I work in inch, this is meant to be slow!] )
G38.2 Z-.25 f2
( Set Z0 at point where probe triggers with offset of +1.008 [this is the thickness of my touch plate. You must adjust this for your plate / setup] )
(G10 L20 = Set Coordinate System // P - coordinate system 0-9 0 = Not active)
G10 L20 P1 Z1.008
( Rapid up to Z.5 above the material )
(G10 L20 P1)
(Use machine coordinates)
G90
G53 G0
(Incremental mode)
G91
(Rapid Z up 1 inches)
G0 Z1
o100 endsub
</pre>In my .ini file
[HALUI]
<pyvcp>
<button>
</button>
</pyvcp>
The following user(s) said Thank You: Sadmeatball, AlexDoran
- AlexDoran
04 Dec 2020 08:40 - 04 Dec 2020 08:59 #191032
by AlexDoran
Replied by AlexDoran on topic Setup Basic Z Touch Off
I got a Macro setup but gmoccapy is just simply being a bitch for some reason.
Everytime I push the button it just gives an error "File not Open". I have no idea what that even means, my config is I think exactly how it should be.
If i open the macro file as if to run it as a program then the MDI / Macro button will work - surely you dont need to open the file in gmocappy before using the button?
Last edit: 04 Dec 2020 08:59 by AlexDoran.
- Thank you received: 4155
04 Dec 2020 14:48 - 04 Dec 2020 14:49 #191069
Replied by rodw on topic Setup Basic Z Touch Off
The macro buttons are ideal for this. This example moves to my laser pointer position and touches off both X&Y
laser_off.ngc
ini file
laser_off.ngc
; goto Laser position offset and touch off
O<laser_off> sub
G21
G91
G0 X -40.685 Y -26.595
g10 l20 p0 x0 y0
O<laser_off> endsub
M2
ini file
# section for main IO controller parameters -----------------------------------
[MACROS]
MACRO = laser_on
MACRO = laser_off
Last edit: 04 Dec 2020 14:49 by rodw.
- AlexDoran
04 Dec 2020 16:07 #191077
by AlexDoran
Mine is setup exactly the same, but I cannot run any Macros.
I NEED to have a program loaded and ready to run, and then when I push the button it appears to search through the loaded program for that subroutine?
If I click the button without a file loaded it just says File Not Open
04 Dec 2020 19:19 #191089
Sounds like its not finding your gcode. I have it in the config folder
- newbynobi
- Thank you received: 394
05 Dec 2020 04:37 #191116
by newbynobi
Replied by newbynobi on topic Setup Basic Z Touch Off
@Alex
it is glas ball looking!
What gmoccapy release do you use?
Is it master or 2.8?
What is the output in the terminal window=
Why do you not post your config folder and the macros?
Norbert
Norbert
The following user(s) said Thank You: AlexDoran
- AlexDoran
06 Dec 2020 10:13 #191227
by AlexDoran
Hi Norbert,
I am using just release 2.8 i think, its just the version included with LinuxCNC, latest download available from the website.
I have attached a ZIP folder of my config and the Macros, its setup exactly the same as the example, but when i click the button it gives the error message "File Not Open"
I think it can see my files, because when i point it to the wrong folder the buttons disappear
Thank you for the help and for the GUI too
- AlexDoran
10 Dec 2020 18:16 #191632
by AlexDoran
Bump?
- Thank you received: 7504
10 Dec 2020 18:58 #191636
Replied by tommylight on topic Setup Basic Z Touch Off
Sorry can not help, have yet to use a probe.
Moderators: newbynobi, HansU
Time to create page: 0.222 seconds
