Tooleditor buttons inactive
02 Jan 2021 16:12 #193848 by atlantis
Tooleditor buttons inactive was created by atlantis
What could be the reason for the buttons "select a tool by number", "change tool with the command M61" and "change tool to the selected one" in the tool editor to be inactive? I have two configs, one that has been made for a test setup on the bench where the buttons are active and another one that I'm working on for an actual machine where they are inactive, but I couldn't find the reason so far.
Kind regards
Martin
02 Jan 2021 17:32 #193859 by newbynobi
Replied by newbynobi on topic Tooleditor buttons inactive
Are both machine homed?
Whal release of gmoccapy do you use?
Norbert
02 Jan 2021 18:20 #193866 by atlantis
Replied by atlantis on topic Tooleditor buttons inactive
The release is 3.0.8.2.
With the one config where the buttons are active they are active whether it's homed or not, therefore I wasn't thinking about that. If it is supposed to work only when the machine is homed the problem may solve itself once the other one is hooked up to the machine and working.
04 Jan 2021 07:15 #194025 by newbynobi
Check if the one that have the button enabled has an entry NO_FORCE_HOMING in the INI file, in that case alle button are enabled directly. If the machine is not homed, and you change a tool, the machine does not now at whitch position it is, so if you want to go to a tool change position, it might travel to a limit.
Norbert
Moderators: newbynobi, HansU
