MPG to Gmoccapy - help
- Jaro
- Thank you received: 9
as I'm still trying to find my way around linuxcnc
can anyone please help me - advise how to configure mpg wheel (100ppm) to gamoccapy.
I want to use the implemented jogging panel (range switching) for control and I have 3 hardware buttons available to select the axis.
mpg i have attached to encoder5 board 7i77.
I will be grateful for any advice
well thank you
- newbynobi
- Thank you received: 394
Note:
- Mine is connected to a 7i73, whitch is connected to a 7i76E, so you will need to change hal pin names
- I use several and components, what are loaded in an other hal file, so you need to add them
- All my mpg is secured by a special button, only if that one is pressed, it will work, that is why I use the and components.
Need more help, just post.
Norbert
- newbynobi
untested!
Norbert
- Jaro
it is clear for me and solved.
only one , you use software encoder, but i've wheel connect on high speed encoder. now i get count x4. is posible to divide this signal?
vhen i want to use soft encoder (input 16,17 on 7i77), there must be common ground with vfield. vhen i connect gnd from 5V (encoder GND) with v field GND, there is error (something like remote error 27 over current). i dont't know why, i think, jumpers are right on my desk....
one more question - is possible to change jog speed durig joigging? I've for manual use classicladder combination of momentary buttons, they simulate push axis, but i'd like to start with jog speed (from 0 to desired jog speed).
Jaro
- newbynobi
I do not use Software encoder! I use hm2_7i76e.0.7i73.0.1.enc0.count as input. The 100 ppr Wheel is connected directly to the mesa card using the 5 V signals.
MESA Documentation says:
ENCODER INTERFACE
The 7I77 provides six channels of quadrature encoder interface with index. Encoder
inputs can be programmed for differential or single ended encoders. The encoder interface
also provides short circuit protected 5V power to the encoders. When used with single
ended encoders, the ENCA+, ENCB+ and IDX+ signals are wired to the encoder and the
ENCA-,ENCB-, and IDX- terminal left unconnected.
So you may connect the 5 V and A and B signals directly to the port and change the counting mode with the jumpers. (If I do understand that correct, please doublecheck)
I have connected analog signal to the Feed override and jog velocity, but I have never tested if that would be possible if during jogging, as I do not use momentary switches to jog, but only the MPG. so if that does work during jogging has to be tested.
Here is my analog input hal file:
# 7i73 hal connections for the analog inputs #
# (c) Norbert Schechner #
loadrt scale names=scale-jog-vel,scale-max-vel
addf scale-jog-vel servo-thread
addf scale-max-vel servo-thread
# the scale is calculated as 1 / 3.3, as the potentiometer is from 0 to 3.3 V
setp scale-jog-vel.gain 0.303030303
setp scale-max-vel.gain 0.303030303
net jog-vel-in hm2_7i76e.0.7i73.0.1.analogin0 => scale-jog-vel.in
net jog-vel-out scale-jog-vel.out => gmoccapy.jog.jog-velocity.direct-value
setp gmoccapy.jog.jog-velocity.analog-enable 1
net max-vel-in hm2_7i76e.0.7i73.0.1.analogin1 => scale-max-vel.in
net max-vel-out scale-max-vel.out => gmoccapy.rapid.rapid-override.direct-value
setp gmoccapy.rapid.rapid-override.analog-enable 1You may use the gmoccapy.jog.jog-velocity hal pin to change jog velocity. and the halui.joint.0.plus / halui.axis.x.plus etc to connect you momentary switches, that might work.
Norbert
- Jaro
my hand wheel works well now.
I tried to redo manual feeds based on "jog manual mode", but I couldn't do it there.
I just couldn't break it up
I have two more encoders available - one I would like to use on the spindle override and the other I currently have on the feed override, but I would like to use it on the jog speed while the selected +/- axis is active. I have encoders connected to the inputs for encoders 03 and 04. I liked the possibility, which was made possible by the flood of old hedenhain, in manual mode it was possible to set the direction of movement and then change the feed from scratch.
I still have a question about spindle overide. I want to use a classic vfd converter 0-10v. is it possible to get such a control voltage (trebars from AOUT5) in some way when I use an encoder and not a potentiometer?
thank you again for your willingness to help.
- newbynobi
i just checked the possibility to change jog speed while axis is moving. It is not possible! You may change the jog speed, while you are moving the axis, but the change will take no effect till you stop the axis and start again a movement.
I do not know if you can connect VFD to 7i77, You may take a look in my connection sheet of the 7i76E
7i76 connection sheet
Norbert
- Online
- Thank you received: 7505
Also the spindle override will work regardless of spindle drive type, when set properly.
- Jaro
VFD is ok, now - works correctly.
Norbert, last thinks about this I'd like to ask you.
I've one momentary push buttons for Rapid speed.
I wanted to use him to speed up during jogging.
however, I assume that if it is not possible to change the speed during Jog, then even this function will not use the data.
Jaro
- newbynobi
Normly on keyboard jogging the Shift Key will do what you want, speed up jogging to max belocity. But how to connect a pysical button to react as the shift key??????
Norbert
