gmoccapy translation to tr
- newbynobi
- Thank you received: 394
10 Mar 2021 20:30 #201703
by newbynobi
gmoccapy translation to tr was created by newbynobi
Thank you very much for your contribution to make gmoccapy even better and user friendlier.
So the language code is tr
I will try to prepare tomorrow the file and poat it here.
Norbert
Norbert
- Thank you received: 2181
10 Mar 2021 21:15 #201718
Replied by cmorley on topic gmoccapy translation to tr
Please make a new thread for that - This is for showing screen designs.
A little discussion is fine but lets try and keep it on task.
- newbynobi
11 Mar 2021 21:04 #201864
by newbynobi
Replied by newbynobi on topic gmoccapy translation to tr
@mkose
attached is the tr.po file.
You need to translate the second string of every entry.
In that file you have also the code lines to look in the code if you have doupt what is the correct entry.
I use gtranslator for the translations, that one is a bit tricky but helpfull.
To upload the file here, I was force to add a txt extension
Norbert
Norbert
12 Mar 2021 13:34 #201964
Replied by andypugh on topic gmoccapy translation to tr
If you enjoy the experience, then you could consider translating all the rest of LinuxCNC:
github.com/LinuxCNC/linuxcnc/tree/master/src/po
As we don't seem to have Turkish there either.
Moderators: newbynobi, HansU
Time to create page: 0.215 seconds
