Gmoccapy cooling hal pin.
02 Apr 2021 19:23 #204548 by MichalHK
Gmoccapy cooling hal pin. was created by MichalHK
Hello,
I read this page linuxcnc.org/docs/2.6/html/gui/gmoccapy.html#_hal_pins
But I dont find any HAL pin input or output that interract with flood or mist cooling.
I would like to connect my cooling pump with this button.
Any idea where to find it?
Thanks so much
02 Apr 2021 21:28 #204563 by newbynobi
Replied by newbynobi on topic Gmoccapy cooling hal pin.
Just connect you pump to halui.cooling-is-on ( check pin name it is called similar) after that the gmoccapy button will turn your pump on through halui
Moderators: newbynobi, HansU
Time to create page: 0.129 seconds
