Here is my code. This is my main .hal file
# Generated by stepconf 1.1 at Fri Jan 29 10:55:56 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out 1 out"
loadrt stepgen step_type=0,0,0
loadrt pwmgen output_type=1
loadrt classicladder_rt numPhysInputs=15 numPhysOutputs=15 numS32in=10 numS32out=10 numFloatIn=10 numFloatOut=10
addf parport.1.read base-thread
addf pwmgen.make-pulses base-thread
addf parport.1.write base-thread
addf classicladder.0.refresh servo-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 24000.0
setp pwmgen.0.offset 0.0
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net probe-in => motion.probe-input
setp parport.0.pin-01-out-invert 1
net spindle-pwm => parport.0.pin-01-out
setp parport.0.pin-02-out-invert 1
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
setp parport.0.pin-04-out-invert 1
net ystep => parport.0.pin-04-out
net ydir => parport.0.pin-05-out
setp parport.0.pin-06-out-invert 1
net zstep => parport.0.pin-06-out
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
net adir => parport.0.pin-09-out
net xenable => parport.0.pin-14-out
net spindle-on => parport.0.pin-17-out
setp parport.1.pin-14-out-invert 1
net flood <= iocontrol.0.coolant-flood => parport.1.pin-14-out
net estop-ext <= parport.0.pin-10-in
net home-x <= parport.1.pin-10-in
net home-y <= parport.1.pin-11-in
net home-z <= parport.1.pin-12-in
net probe-in <= parport.1.pin-13-in-not
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 5000
setp stepgen.0.stepspace 5000
setp stepgen.0.dirhold 20000
setp stepgen.0.dirsetup 20000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net home-x => joint.0.home-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 5000
setp stepgen.1.stepspace 5000
setp stepgen.1.dirhold 20000
setp stepgen.1.dirsetup 20000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
net home-y => joint.1.home-sw-in
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 5000
setp stepgen.2.stepspace 5000
setp stepgen.2.dirhold 20000
setp stepgen.2.dirsetup 20000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
net home-z => joint.2.home-sw-in
net estop-ext => iocontrol.0.emc-enable-in
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
# Load Classicladder without GUI (can reload LADDER GUI in AXIS GUI
loadusr classicladder --nogui custom.clp
this is my tool_senor.glade file
<?xml version="1.0"?>
<interface>
<requires lib="gtk+" version="2.16"/>
<!-- interface-requires gladevcp 0.0 -->
<!-- interface-naming-policy project-wide -->
<object class="GtkWindow" id="window1">
<child>
<object class="GtkFrame" id="frm_tool_sensor">
<property name="visible">True</property>
<property name="label_xalign">0.5</property>
<child>
<object class="GtkAlignment" id="ali_tool_sensor">
<property name="top_padding">5</property>
<property name="bottom_padding">5</property>
<property name="left_padding">5</property>
<property name="right_padding">5</property>
<child>
<object class="GtkVBox" id="vbox_tool_sensor">
<child>
<object class="GtkHBox" id="hbox_tool_sensor">
<child>
<object class="GtkLabel" id="lbl_tool_sensor">
<property name="label" translatable="yes">Probe:</property>
</object>
<packing>
<property name="expand">False</property>
<property name="fill">False</property>
<property name="position">0</property>
</packing>
</child>
<child>
<object class="HAL_LED" id="led_tool_sensor">
<property name="pick_color_on">#0000ffff0000</property>
<property name="pick_color_off">#ffff00000000</property>
</object>
<packing>
<property name="position">1</property>
</packing>
</child>
</object>
<packing>
</packing>
</child>
</object>
</child>
</object>
</child>
<child type="label">
<object class="GtkLabel" id="lbl_frm_tool_sensor">
<property name="label" translatable="yes"><b>Tool Probe</b></property>
<property name="use_markup">True</property>
</object>
</child>
</object>
</child>
</object>
</interface>
I hope this makes sense? I have a file also called tool-sensor.hal which is where I need the code to turn the LED light to green once the tool probe touches (shorts) and then back to red when its off the tool probe.
