Hey,
Thanks for the reply.
I know i am a newbie and make a lot of mistakes, eventually i'm lucky to get a working configuration.
For me it is a matter of trying and error....
Ultimately it is educational.
Now I'm back with something inexplicable to me ....
I made a test panel in glade with a button, led and label.
hall pins are indeed created.
But when I want to use the pins ....
- net test paneel.led1 <= halui.machine.is-on
I get the error that the pin does not exist
I have used this as an example
gnipsel.com/linuxcnc/gladevcp/index.html
Do have to make an adjustment because
- net spindle-state gladevcp.hal_led1 <= motion.spindle-on
no longer exists
changed in
- net spindle-state gladevcp.hal_led1 <= halui.machine.is-on
and it worked. But it doesn't work in my project ....
Short,
A panel created, tested in linuxcnc, pins exist.
The test line in the custom_postgui.hal and no more booting ....
How do I connect to the hall pins in gmoccapy?
where should I place the connections?
Without the custom_postgui.hal configuration starts up and the pins are created,
but with the connections in custom_postgui.hal, the pins don't exist when gmoccapy runs them.
