Startup hangs with RS274NGC_STARTUP_CODE = M52P1
5 years 5 months ago #207820 by mwinterm
Hello,
I'm trying to enable program jog at startup by
RS274NGC_STARTUP_CODE = M52P1...
This works fine with AXIS. When done with GMOCCAPY the startup of GMOCCAPY hangs. When executing M52P1 after startup of GMOCCAPY everything works fine.
Any ideas?
Regards,
Marc
5 years 5 months ago #207822 by mwinterm
...actually I have to correct my statement: GMOCCAPY is starting up after approximately 5min but behaves very sluggish. Every click takes several seconds to execute.
5 years 5 months ago #207873 by newbynobi
May be, because the sliders are initialized at start up and may be influenced by M52. I have never used that feature and I am sorry to let you know, that I will not get time to look into it for several weeks or even month.
Would it be possible to set M52 with a macro button?
Norbert
5 years 5 months ago #208014 by mwinterm
Hello Norbert,
thanks for the feedback. Yes I will try to find a way to work around it.
But enjoying very much using Gmoccapy so far. Reminds me of a Heidenhain in some aspects which is my preferred commercial control I used so far.
Best regards,
Marc
5 years 5 months ago #210081 by mwinterm
Hello Norbert,
I'm experiencing the same issue again but this time by just specifying a Python remap. To test I took gmoccapy.sim that ships with 2.8.1 and just added
REMAP=M910 modalgroup=10 argspec=PQ python=m910
and the M910 python function was basically empty (only issuing a message). Again the same behavior, takes forever to start-up and behaves very sluggish. The latest 2.9 master showed the same behavior.
Regards,
Marc
5 years 5 months ago #210083 by newbynobi
Please post the python file, so I can check exactly with your file what happens.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.281 seconds
