Disable home buttons on input condition (avoid collision)
- emcPT
- Thank you received: 95
18 May 2021 08:04 #209312
by emcPT
Disable home buttons on input condition (avoid collision) was created by emcPT
Good morning,
I would like to disable the possibility to home the machine if a determined input is disable.
It would be nice to leave the home buttons "gray" in this case.
The reason is that my custom machine might be physically in a position that is dangerous to home the machine and a collision might occur during the home process that is normally unattended.
To prevent this I already have a sensor that is TRUE if all is on position for a safe home or jog. For jogging the motion.feed-inhibit that I already have connected to this sensor works as expected but this does not cover the home.
Thank you
Thank you
- Thank you received: 4145
18 May 2021 10:52 #209332
Replied by rodw on topic Disable home buttons on input condition (avoid collision)
My first thought was we need a halui.home-disable pin but I could not find where the halui source lives.
If your custom GUI only used halui.home-all to home the machine, couldn't your new pin be and2 'ed with the screen home button pin and connected to home-all. The gui screen handler could disable buttons based on your pain value.
The following user(s) said Thank You: emcPT
- phillc54
- Thank you received: 2100
18 May 2021 12:04 #209342
by phillc54
Replied by phillc54 on topic Disable home buttons on input condition (avoid collision)
The following user(s) said Thank You: emcPT, rodw
- emcPT
18 May 2021 16:29 #209357
by emcPT
Replied by emcPT on topic Disable home buttons on input condition (avoid collision)
The motion.homing-inhibit worked perfectly !
The following user(s) said Thank You: phillc54, rodw
Moderators: newbynobi, HansU
Time to create page: 2.427 seconds
