Hide 4th axis if used for tool changer
28 Jul 2021 11:22 - 28 Jul 2021 11:30 #216120 by HalaszAttila
Hide 4th axis if used for tool changer was created by HalaszAttila
Hello,
i use latest (v2.8.2) version with Gmoccapy, and i dont find the checkbox in settings tab for hiding 4th axis.
I use this for tool changer, and would be good to hide it.
I found this in changelog:
ver. 2.0.19
- deleted the settings to hide axis 4 if used as tool changer as that is not longer needed on Joint Axis branch
My question is, how can i hide 4th axis from DRO, and jog buttons from gmoccapy?
And h ow can i use this feature:ver 3.1.3.8 - changed the hide command to be able to hide any element of the GUI
Thanks,
 Attila.
Last edit: 28 Jul 2021 11:30 by HalaszAttila.
28 Jul 2021 15:01 #216125 by Aciera
Replied by Aciera on topic Hide 4th axis if used for tool changer
In your INI file [TRAJ]-section change
COORDINATES = xyza
to
COORDINATES = xyz
also probably the same in the [DISPLAY]- section for the GEOMETRY entry.
The following user(s) said Thank You: HalaszAttila
28 Jul 2021 15:14 #216126 by HalaszAttila
Replied by HalaszAttila on topic Hide 4th axis if used for tool changer
Thanks, i modified the INI, and the A axis is hidden in gmoccapy. No DRO, and jog buttons. But now if i want to program the axis (for example: G53 G0 A180), i get: Bad Character 'a' used message, and cant move the axis.
I have remapped M6, and need to move axis from ngc macro running during M6.
28 Jul 2021 16:42 #216134 by Aciera
If you need to use the A coordinates in gcode then I don't think you can hide the axis in the DRO since gmoccapy seems to check for the settings in the [TRAJ] section which in turn sets up the trajectory planner.
28 Jul 2021 21:21 #216150 by HalaszAttila
The gmoccapy changelog say:
- deleted the settings to hide axis 4 if used as tool changer as that is not longer needed on Joint Axis branch.
No loger needed on Joint Axis branch. Maybe has a solution for hiding 4th axis if deleted from some reason.
29 Jul 2021 06:14 #216189 by Aciera
Not sure how that's supposed to work.
Maybe somebody else has a solution?
01 Aug 2021 02:03 #216571 by andypugh
Replied by andypugh on topic Hide 4th axis if used for tool changer
You are asking the GUI developer to be psychic here. You sort of want the axis sometimes, but not others.
If it's the tool changer then it isn't an axis.
Really, it's not.
There are other ways to do this.
01 Aug 2021 16:26 #216624 by newbynobi
Replied by newbynobi on topic Hide 4th axis if used for tool changer
Hiding the 4th axis is not longer needed since the joint axis branch has been merged.
For a tool changer no axis is needed, but a joint.
It si not so easy to add, but may be this thread could help:
extra joints not related to motion controler
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.372 seconds
