Custom homing procedure
  • mariusl
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 2 months ago #219077 by mariusl
Custom homing procedure was created by mariusl
I am upgrading an old Mach3 installation with a 7i92 and Linuxcnc using Gmoccapy as GUI.
There is a special procedure that is followed when the machine is homed. This was done in the Mach3 screen. Below is the code that is executed when home all is pressed.
The rotation axis has n pin that is engaged when the homing cycle begins. This will keep the axis in a known place and is used as the zero. The axis is then moved by some amount to calibrate the position to a true zero.
How would I approach this in Gmoccapy?
Code "G54" Code "F4000"  SetFeedRate(2000 /60) DoButton( 24 ) DoButton( 23 ) DoButton( 22 ) While ismoving() Wend DoButton( 8 )  DoButton( 9 )        Code "G1 A0 F2000" While ismoving() Sleep(100) Wend ActivateSignal(Output2) 'set the pin Sleep(500)  Code "G1 A-180"  ' turn the knife anti-clockwise for a half turn While ismoving() Sleep(100) Wend DoButton(11)  ' clear the DRO Code "G1 A-180"  'turn the knife again to make sure of one full turn and lock-up While ismoving() Sleep(100) Wend DoButton( 11 )  ' do the mach referencing SetDro(3,270) ' to head the knife in th eright direction DeActivateSignal(Output2) ' unlock the pin Code "G1 A0" Code "G1 X-12" Code "G1 Y87" While ismoving() Sleep(100) Wend DoButton( 8 )  DoButton( 9 ) Code "G55" DoButton( 11 ) Code "G54"
Regards
Marius
www.bluearccnc.com
5 years 2 months ago #219120 by cmorley
Replied by cmorley on topic Custom homing procedure
linuxcnc's homing procedure is in fact quite configurable but not customizable.
but is it enough to detect homing is happening, and move the pin with HAL ?
5 years 2 months ago - 5 years 2 months ago #219143 by nkp
Replied by nkp on topic Custom homing procedure
INI
all axis
HOME_OFFSET = 0
HOME = 0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_FINAL_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
MDI_COMMAND = o<yourcode>call
HAL
net homed axis.2.homed halui.mdi-command-00
(here probably the ladder needs to be used rising edge )
NGC
yourcode.ngc
o<yourcode> sub
o<yourcode> endsub
Last edit: 5 years 2 months ago by nkp.
  • mariusl
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 2 months ago #219146 by mariusl
Replied by mariusl on topic Custom homing procedure
The problem with this approach is that the pin must be released before the homing is done in order for the axis to be set to the offset value. It cannot turn with the pin activated
Regards
Marius
www.bluearccnc.com
5 years 2 months ago #219148 by cmorley
There are pins such as joint.N.homing that indicate when homing starts.
Could you use that to move the pin?
  • mariusl
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 2 months ago #219149 by mariusl
I could if it does not stay active during the homing procedure. The problem is that the pin must be released before the axis does the last move to the programmed offset of the home switch. There is no home switch on the rotary axis so they used a pin to lock the turret in a known position and then apply an offset to a calibrated position.
Regards
Marius
www.bluearccnc.com
5 years 2 months ago - 5 years 2 months ago #219152 by Aciera
Replied by Aciera on topic Custom homing procedure
Maybe feeding the homing pin signal through a TIMEDELAY component would solve that.
linuxcnc.org/docs/2.8/html/man/man9/timedelay.9.html
[edit]
When you say 'turret' is this a tool changer? If so, it might be worth trying to not run it as an actual axis.
Last edit: 5 years 2 months ago by Aciera.
  • mariusl
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 2 months ago #219159 by mariusl
No it's not a tool changer but a rotary knife that is mounted on a rotating axis. The little collar that holds the knife holder I call the turret.
Regards
Marius
www.bluearccnc.com
5 years 2 months ago #219216 by cmorley
From the motion man page:
joint.N.home-state OUT S32 (DEBUG)
              homing state machine state
       joint.N.home-sw-in IN BIT
              Should be driven TRUE if the home switch for this joint is closed
       joint.N.homed OUT BIT (DEBUG)
              TRUE if the joint has been homed
       joint.N.homing OUT BIT
              TRUE if the joint is currently homing
Should be something usable there.
The following user(s) said Thank You: nkp
  • mariusl
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 2 months ago #219225 by mariusl
Thanks Chris, I missed that one. I think that will be just what I need. I will try and incorporate that into a component that will look at the is_homing signal and apply the pin. After some delay I will set the switch pin to true and remove the pin signal. That should fake the homing cycle, I think??
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.172 seconds
