LCNC 2.8 - Language bugs
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Jun 2022 18:14 #245609 by zz912
I am trying translate Gmoccapy LCNC 2.8.8 to Czech language.
A lot of texts works, but home all axis not.
The problem is not only for my translate. DE translate have same problem.
23 Jun 2022 18:37 - 23 Jun 2022 18:38 #245712 by HansU
Replied by HansU on topic Translate Tooltip Home button dont work
It seems that you are not yet using Weblate for your translation.
You just have to add your language here hosted.weblate.org/projects/linuxcnc/gmocappy/.
Then I would strongly recommend you to do your translations there if you want to have them in master.
If you have already worked a lot on your translation based on the po file - I think there is a way to get your translations into Weblate.
Regarding the primary problem - I'll have a look...
Last edit: 23 Jun 2022 18:38 by HansU.
24 Jun 2022 14:51 #245791 by HansU
I fixed the strings in 2.8 as well as in master.
  • zz912
  • Platinum Member
  • Platinum Member
29 Jun 2022 08:35 #246141 by zz912
Replied by zz912 on topic Translate Tooltip Home button dont work
I am a very conservative person, so I will use version 2.8 for as long as possible.
If I created Czech for LCNC, will it be possible to easily switch LCNC to English in version 2.9? I am currently compiling the whole LCNC using "make" and I have a RIP installation, most LCNC users use live distribution and here I do not know how to change the language and whether it is possible at all. Czech is interesting only for some individuals, others would like to kill me if suddenly a change came and they had everything in Czech instead of English.
I also have a problem that I am not a machinist and I do not know suitable translations for some expressions. In addition, I find that Gmoccapy has features that I don't know what they are for, let alone how I translate their controls.
I tried to start a translation thread on the Czech forum
forum.strojirenstvi.cz/viewtopic.php?t=41960
but no one interested this topic. Maybe someone will be in the future.
  • zz912
  • Platinum Member
  • Platinum Member
29 Jun 2022 09:19 #246142 by zz912
Is there a way to get this fix?
I use RIP Installation. I download source from github:
I don't know the difference between "Branches" and "Tags"
Is "2.8" future version 2.8.3 in this moment?
Is in "2.8" this fix?
  • zz912
  • Platinum Member
  • Platinum Member
29 Jun 2022 19:15 #246190 by zz912
I tried compile version 2.8 and it works. Thank you for FIX.
  • zz912
  • Platinum Member
  • Platinum Member
29 Jun 2022 20:36 - 07 Jul 2022 19:55 #246203 by zz912
I found next bug:
Gmoccapy.py
line 1160
old: btn.set_property("tooltip-text", _("Press to jog axis {0}".format(axis)))
new: btn.set_property("tooltip-text", _("Press to jog axis {0}").format(axis))
line 1179
btn.set_property("tooltip-text", _("Press to jog joint {0}".format(joint)))
same problem
line 1229
btn.set_property("tooltip-text", _("Press to run macro {0}".format(name)))
same problem
I fixed it like you. Can I ask you for fix it in Github?
Edit: I made Pull request
github.com/LinuxCNC/linuxcnc/commit/cc1b...ff0bde4ffd9568313549
Last edit: 07 Jul 2022 19:55 by zz912.
  • zz912
  • Platinum Member
  • Platinum Member
03 Jul 2022 13:46 - 03 Jul 2022 14:16 #246506 by zz912
I probably found another bug related to the translation. I don't want to start another thread.
Last edit: 03 Jul 2022 14:16 by zz912.
  • zz912
  • Platinum Member
  • Platinum Member
03 Jul 2022 14:20 #246507 by zz912
I don't know if it's a bug, but it's strange that I'm being asked to translate text with underscores.
  • zz912
  • Platinum Member
  • Platinum Member
03 Jul 2022 15:07 #246511 by zz912
I didn't find a way to translate the "command" label.
Moderators: newbynobiHansU
Time to create page: 0.222 seconds
