Gmoccapy settings won't unlock
02 Feb 2024 05:40 - 02 Feb 2024 05:58 #292194 by 0jw
Gmoccapy settings won't unlock was created by 0jw
Hello, I'm having a bit of a problem with gmoccapy, I'm using a mesa 7i92 with 6.3 kernel. I get some errors when starting, most of which I don't understand. When I try to use 123 to unlock settings page it doesn't do anything.
 this is the debug info if anyone knows what I need to fix.
Debug file information:
25326
Note: Using POSIX realtime
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
(gmoccapy:25979): Gtk-CRITICAL **: 12:08:08.092: gtk_entry_set_text: assertion 'text != NULL' failed
[Gmoccapy.GMOCCAPY.GETINIINFO][[33mWARNING[0m]  No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file (getiniinfo.py:282)
12:08:13.551 WARNING Config: mousetweaks GSettings schema not found, mousetweaks integration disabled.
/usr/lib/python3/dist-packages/gi/overrides/GObject.py:493: Warning: ../../../gobject/gsignal.c:2772: instance '0x5885380' has no handler with id '50341834'
  return func(*args, **kwargs)
[Gmoccapy][[31mERROR[0m]  Found an error!
The following information may be useful in troubleshooting:
  File "/usr/lib/python3/dist-packages/hal_glib.py", line 414, in update
    self.merge()
  File "/usr/lib/python3/dist-packages/hal_glib.py", line 335, in merge
    ferror.append(self.stat.joint[j])
KeyboardInterrupt
 (gmoccapy:62)
/usr/bin/linuxcnc: line 977: 25979 Killed                  $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
25927
25975
Stopping realtime threads
Unloading hal components
Last edit: 02 Feb 2024 05:58 by 0jw.
03 Feb 2024 23:51 #292342 by 0x2102
Replied by 0x2102 on topic Gmoccapy settings won't unlock
Most of them are warnings about missing information in your INI file - therefore Gmoccapy is using build-in defaults.
Try 0123 to unlock the settings page. I don't recall a 100% but I think it starts with 0.
03 Feb 2024 23:57 #292344 by tommylight
Replied by tommylight on topic Gmoccapy settings won't unlock
www.linuxcnc.org/docs/html/gui/gmoccapy....occapy:settings-page
says 123 so no idea why it does not work.
Moving this to "GmoccaPy" section.
04 Feb 2024 05:24 #292357 by cmorley
Replied by cmorley on topic Gmoccapy settings won't unlock
opening the preference file will show the unlock code. 123 is standard.
But I think you have something else going on.
Did this ever work properly?
04 Feb 2024 16:32 #292414 by HansU
Replied by HansU on topic Gmoccapy settings won't unlock
As far as I know, yes.
@0jw Does this also happen on a sim config?
Are you using the latest version from master or the latest release (2.9.2) ?
If I understand it correctly, LinuxCNC throws that error when you try to enter the settings page?
Moderators: newbynobi, HansU
Time to create page: 0.430 seconds
