Setup Sheet as Embedded Tab
- zz912
- Thank you received: 98
31 Jul 2024 18:26 #306552
by zz912
Replied by zz912 on topic Setup Sheet as Embedded Tab
@HansU
Have you tried patching/running this source code? I would appreciate some M/G code help.
forum.linuxcnc.org/gmoccapy/53025-setup-...-embedded-tab#303550
- HansU
- Thank you received: 217
18 Sep 2024 20:21 #310412
by HansU
Replied by HansU on topic Setup Sheet as Embedded Tab
Thanks for the hint! I played a bit around with this example and indeed it is working, BUT:
I added the file-loaded signal and then it begin to behave different than inside gmoccapy code (user command file).
As a VCP I only get this message when I open another file.
But inside gmoccapy I get the message on every reload (reload button click).
And the message graphics-gcode-properties I don't get at all in a VCP.
Moderators: newbynobi, HansU
Time to create page: 0.099 seconds
