Jog keys for A axis
08 Aug 2024 10:13 #307252 by zz912
Replied by zz912 on topic Jog keys for A axis
If Aciera agrees, I can create a Pull Request.
However, it is necessary to define which key letters are to be used.
This must be approved by Norbert.
It will be necessary to test how this change will affect the 3 axis configuration.
08 Aug 2024 11:35 #307255 by Aciera
Replied by Aciera on topic Jog keys for A axis
I don't use keyboard shortcuts so the changes I posted have been reverted on my local machine. If you are interested to have those changes as a PR then please go ahead.
08 Aug 2024 20:50 #307279 by zz912
To Aciera: Can I ask you for Pull Request?
I would also like this improvement.
For at least five (5) axis please but all six will be better.
To Mariusl:What keys do you suggest?
Home => +A
End => -A
???? => +B
???? => -B
???? => +C
???? => -C
Here are the already occupied keys:
github.com/LinuxCNC/linuxcnc/blob/b054eb...ccapy.py#L3052-L3295
09 Aug 2024 06:05 #307290 by newbynobi
Replied by newbynobi on topic Jog keys for A axis
Hallo,
Keyboard shortcuts are IMHO dangerous and will only be used on hobby machines. I use a handmade hand MPG for that. But implementing more keys will not lead to a more or less dangerous behavior.
So implementing more keys is not the case. We should try to maintain the behavior equally on every GUI, so I suggest to use the same keys as on AXIS GUI.
Norbert
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Aug 2024 10:17 #307329 by mariusl
Replied by mariusl on topic Jog keys for A axis
I used Home and End for the A axis on a regular 4 axis machine and then I used Home and End for B axis and "[" and "]" for C axis on a five axis machine.
I think Norbert's suggestion of looking at the keys in Axis is probably the right way.
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
09 Aug 2024 10:21 #307331 by mariusl
Norbert
I have more machines in factories using keyboard only than MPG. MPG's are not desired on routers by most users.
How do you jog with an MPG in joint mode? I am sure you can only use keyboard.
Regards
Marius
www.bluearccnc.com
09 Aug 2024 16:13 #307367 by zz912
I foung in AXIS only:
("[, ]", _("Jog fourth axis or joint")),
Moderators: newbynobi, HansU
Time to create page: 0.135 seconds
