İnstall glade
2 years 2 months ago #308131 by Aciera
Replied by Aciera on topic İnstall glade
Forgot:
to access the values in Gcode (eg the value 9.2 above) you can use:
#<_hal[testpanel.hal_spinbutton1-f]>
Important notice:
I strongly recommend to use a quebuster command like 'M66 E0 L0' right before reading a hal pin in Gcode otherwise the readahead may read the pin much before code execution gets to that line.
The following user(s) said Thank You: Moutomation
2 years 2 months ago #308151 by Moutomation
Replied by Moutomation on topic İnstall glade
Thank you very much
2 years 2 months ago #308263 by pawel77
Replied by pawel77 on topic İnstall glade
With 2.9 I have problem to open glade files done in 2.8.4 version, they request 3.8 while 3.4 glade is available.
In synaptic manager gladevcp is not available.
thanks for any help
2 years 2 months ago #308269 by Aciera
Usually you can simply click 'OK' and save the file.
The following user(s) said Thank You: pawel77
2 years 2 months ago #308284 by pawel77
OK thanks if this is the solution. However it changes the layout of elements during opening, I will have to arrange them again.
I thought the gladevcp of 2.8.4 is better and is available in 2.9.
2 years 2 months ago #308365 by Moutomation
What should I do to ensure that the values ​​I write are not lost and persist when Linuxcnc is turned off and on?
Moderators: newbynobi, HansU
Time to create page: 0.308 seconds
