Macros. File not open
1 year 8 months ago #320926 by zz912
Replied by zz912 on topic Macros. File not open
Sub has not same name at start and end.
The following user(s) said Thank You: tommylight, Aciera
1 year 8 months ago #320980 by Yaroslav
Replied by Yaroslav on topic Macros. File not open
This is a random error. I have many other files that are not working. At the moment I am solving the problem by moving them to the root of the machine configuration folder.
1 year 8 months ago #322210 by JuFu
Replied by JuFu on topic Macros. File not open
I have the same problem.
Created about 10 macros and all worked fine.
I edited some of the macros and changed names, all of a sudden the message "File not open" shown when I try to run the macro.
Verified 10 times to be sure file name, MACRO = in ini-file, first and last line (before M2) has correct name.
The macros not edited still work, but the macros I changed the names donot.
@Yaroslav: did you find a solution?
1 year 8 months ago #322268 by Yaroslav
I solved the issue by moving the files to the root of the machine configuration folder.
1 year 8 months ago #322270 by JuFu
All of the files or macros only?
1 year 8 months ago - 1 year 8 months ago #322361 by Yaroslav
  Copy only macros.
Last edit: 1 year 8 months ago by Yaroslav.
Moderators: newbynobi, HansU
Time to create page: 0.289 seconds
