gmoccapy - tool change and edge finder do not work
1 year 8 months ago #321935 by JuFu
Hallo, I installed LinuxCNC 2.9.4 with gmoccapy 3.4.8 on my 3 axis mill (router).
While I can operate (home all 3 axis and move manually and by NC program) the tool change (and measurement) does not function.
When I click on the edge finder button at the bottom of gmoccapy screen, nothing happens.
I would like to debug and find out what's wrong on my setup.
How can I trace what gmoccapy is doing? What should it do when I click the edge finder icon?
Does gmoccapy call a macro? or another program to execute?
Hope for help
Juergen
1 year 8 months ago #321939 by zz912
If you want find out default behavior, you should try sim (simulation) configuration of Gmoccapy:
configs/sim/gmoccapy/gmoccapy.ini
Is it your first instalation, or did you upgrade from 2.9.3 to 2.9.4?
Here is manual:
linuxcnc.org/docs/stable/html/gui/gmoccapy.html
Here is source code:
github.com/LinuxCNC/linuxcnc/blob/2.9/sr...gmoccapy/gmoccapy.py
1 year 8 months ago #322009 by JuFu
thanks for the reply.
It's a fresh installation of latest gmoccapy version.
I'm not a software guy, but followed the manual as much as possible.
Have no chance to dig into python stuff.
As mentioned, referencing the axis, MDI, already works. Even macros.
Its the M6 what does not work..
1 year 8 months ago #322019 by newbynobi
May be you are missing parts in your config.
Post your complete folder.
Norbert
1 year 8 months ago #322030 by Sziggy_NC
I am not sure what the edge find button is.
I am assuming that your router needs to move to a certain spot for the tool change. Look into tool change at G30. Make sure your program retracts the Z high enough before every tool change.
If you have an automatic tool changer you will need to remap the M6 command.  linuxcnc.org/docs/html/remap/remap.html#...lated_codes_t_m6_m61
1 year 8 months ago - 1 year 8 months ago #322034 by JuFu
File Name: Foxy_gmoccapy.zip
File Size:23.01 KB
attached the compressed config folder.
Last edit: 1 year 8 months ago by JuFu.
Moderators: newbynobi, HansU
Time to create page: 0.165 seconds
