gmoccapy - tool change and edge finder do not work
1 year 8 months ago #322082 by JuFu
folder posted
1 year 8 months ago #322110 by Sziggy_NC
Could I get a picture of the edge find button? If you use print screen button on your keyboard it will allow you to copy the screen to the clipboard or save a picture of your screen to your hard drive.
What behavior do you want M6 to do?
Tool change at G30 will allow you to manually change tools away from the part.
  1. Add "TOOL_CHANGE_AT_G30=1" to the [EMCIO] portion of your INI file.
  2. Power on your machine & home all axis.
  3. Jog to the position you want to do manual tool changes at.
  4. Type G30.1 into MDI and run it. This will save the current machine position as the location to go to when a tool change is called.
  5. Test the machine. It should now rapid to this location when you call M6
linuxcnc.org/docs/2.6/html/gcode/gcode.html#sec:G30-G30_1
1 year 8 months ago #322111 by Sziggy_NC
The parameters that store the location of the G30 are persistent. Even after rebooting the PC the G30 location will be the same. You only need to do G30.1 once.
1 year 8 months ago #322874 by JuFu
Tanks for the tip. It helped!
In the meanwhile I chnged to Probe Basic and got it to wook.
Tool measuremt and probing works now.
Moderators: newbynobi, HansU
Time to create page: 0.090 seconds
