Spindle speed and jogging speed slider problems
- Reddiamonduk
23 Feb 2025 13:20 - 23 Feb 2025 15:40 #322360
by Reddiamonduk
Spindle speed and jogging speed slider problems was created by Reddiamonduk
Hi, does anyone know how to change the speed sliders so that they stop when released on a touch screen. If I just move a small amount it's fine but if I hold too long they will keep going to the bottom or top of the scale before I can then go back slowly to the speed I want?
Last edit: 23 Feb 2025 15:40 by Reddiamonduk. Reason: Added video
- unknown
- Thank you received: 325
25 Feb 2025 22:38 #322636
by unknown
Replied by unknown on topic Spindle speed and jogging speed slider problems
Just a guess........
If your touch screen comes up as HID (assuming USB) you may be able to modify the mouse properties in "control center" . Sorry I can't be of more help, as I haven't got access to my setup.
The following user(s) said Thank You: Reddiamonduk
- newbynobi
- Thank you received: 394
26 Feb 2025 06:10 #322653
by newbynobi
Replied by newbynobi on topic Spindle speed and jogging speed slider problems
Looks like the screen is reacting with key events like a keyboard.
Like a keyboard repeats the key every X millis and store the number of events.
like moving the machine with a encoder and a fixed step. If you turn the hand wheel, the controller will count the encoder counts and even if you stop turning the wheel, the machine goes on moving until the calculated distance is reached.
I can unfortunately not tell you how to change that behavior. I would search for something like key repeat time.
I do use an older model of a Faytech Touch and I am not able to reproduce the bhavior.
Norbert
Norbert
- Reddiamonduk
27 Feb 2025 22:25 - 27 Feb 2025 22:32 #322831
by Reddiamonduk
It's the latest download version.
LinuxCNC 2.9.4 Debian 12 Bookworm PREEMPT-RT ISO
Replied by Reddiamonduk on topic Spindle speed and jogging speed slider problems
langdons post=322591 userid=41217
What the...
Weird.
Super weird.
Perhaps try a drifferent GUI?
Looks like a touchscreen issue?
Touchscreen configuration on Linux is kinda impossible, at least on Ubuntu.
What OS are you running?
Last edit: 27 Feb 2025 22:32 by Reddiamonduk.
- Reddiamonduk
27 Feb 2025 22:29 #322832
by Reddiamonduk
Thanks, I think you may be right, if so I don't think there is much I can do about it other than change the screen.Looks like the screen is reacting with key events like a keyboard.
Norbert
- Reddiamonduk
27 Feb 2025 22:35 #322833
by Reddiamonduk
Thanks, I'll look into that and see if it makes any difference.
- newbynobi
28 Feb 2025 06:16 #322845
by newbynobi
May be the driver has a setting to set the repetition rate ?
My one reakts with a long touch like preesing the right mouse button. So I was also forced to set that time longer to be able to hold down the touch buttons for longer.
Norbert
Norbert
- Reddiamonduk
28 Feb 2025 09:33 #322859
by Reddiamonduk
I will look into the keyboard repeat settings to see if that changes anything, I'll have to look it up as I've only ever used windows so no idea where those settings would be but I'm sure google will let me know.May be the driver has a setting to set the repetition rate ?
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.344 seconds
