New GMOCCAPY Installation - Duplicate Object IDs in gmoccapy.glade
- djones@burketruck.com
26 Feb 2025 10:47 #322721
by djones@burketruck.com
New GMOCCAPY Installation - Duplicate Object IDs in gmoccapy.glade was created by djones@burketruck.com
I am in the process of getting our Mazak VTC16B Retrofit wrapped up. We ended up using dmitry's NYX hardware & IO interface. For config, we took one of the nyx MDS sample configs and adapted it to our I/O. We got everything to work in Axis, now we are trying to switch to GMOCCAPY.
The issue we are having is that I keep getting an error when loading any sample version (or our own local version) of gmoccapy, I keep getting this error along the lines of "/usr/share/gmoccapy/gmoccapy.glade:5576:1 Duplicate object ID 'chk_use_kb_shortcuts' (previously on line 4179) (8)
(gmoccapy:62)". I confirmed there is a duplicate block in gmoccapy.glade. I have searched the github issues but can't seem to find anything on if this is a known issue or not. Is this a known issue with Gmoccapy in 2.9.4, or does it appear like I have a corrupted install? Any help would be much appreciated.
I've attached our machine hardware info, error report, & gmoccapy.glade file.
Thanks!
Thanks!
- HansU
- Thank you received: 217
26 Feb 2025 14:40 #322741
by HansU
Replied by HansU on topic New GMOCCAPY Installation - Duplicate Object IDs in gmoccapy.glade
it seems that your glade file is corrupted somehow. If I look at the glade file in 2.9.4: github.com/LinuxCNC/linuxcnc/blob/v2.9.4...ccapy/gmoccapy.glade - I can't find those duplicates.
How did you install LinuxCNC 2.9.4? Directly from the ISO image or updated from 2.9.3 or earlier?
26 Feb 2025 14:50 #322746
Replied by djones@burketruck.com on topic New GMOCCAPY Installation - Duplicate Object IDs in gmoccapy.glade
It is installed from Dmitry's NYX53, which is mainly bringing the NYX stuff up to par with 2.9.4. This is the link: yurtaev.com/nyx32.html
- HansU
26 Feb 2025 14:53 - 26 Feb 2025 14:55 #322747
by HansU
In this case you should ask Dmitry as I don't know his sources from he built his debs.
Not sure if it would overwrite his drivers if you install the official LinuxCNC package but it could be worth a try.
Last edit: 26 Feb 2025 14:55 by HansU.
Moderators: newbynobi, HansU
Time to create page: 0.303 seconds
