Gmoccapy Touch-Off Offsets
16 Apr 2025 04:17 #326425 by electrosteam
Gmoccapy Touch-Off Offsets was created by electrosteam
3-axis mill with RPi 4B and LC 2.9.3 from Download page, and Gmoccapy 3.4.6 - runs a job fine.
Offset Values:
In Axis, Touch-Off populates with a value generally within 0.001 mm of the value entered
Minor corrections are often successful, but sometimes ignored.
In Gmoccapy, Touch-off x=0, y=0, z=0, G54 populates with a value, like z=0.511.
    - Touch-off often leaves small errors on the DRO, like 0.008 mm.
    - I seem to run in circles trying to get the Offsets Page to agree with the DRO display, the G54 values, and the current position.
Suggestions ?
16 Apr 2025 22:57 #326493 by electrosteam
Replied by electrosteam on topic Gmoccapy Touch-Off Offsets
I find it odd that a computer cannot populate a memory location with a value entered.
Goes against 65 years of experience.
The Z0.511 error is actually disconcerting.
I tried increasing the precision value from 3 to 4, still strange results.
Note that the errors are either very small, or only arise when setting the Offsets.
Touch-Offs prior to program Run are good.
But, that means I cannot rely on the Offsets.
17 Apr 2025 11:38 #326514 by electrosteam
Spent some time chasing the mysterious Z-0.511 value.
The value pops up at Homing.
Cleared linuxcnc.var and linuxcnc.var.backup without joy.
Went through all the setup files, until I got to tool.tbl - and there it was, the cutting length of tool T1 = 0.511.
Launched Gm, selected the tool editor, and T1 was 0.511, and ticked as selected.
Cleared the tick and closed/opened Gm - but the 0.511 comes back, with T1 selected in the tool table !!
Found a youtube clip by sliptronic that includes a view of his tool table.
T1 is selected and set to length 0.00.
It could be the default behaviour of Gm is to automatically load T1, then allow for its length in the displayed position.
Edited my tool table to make T1 cut length 0.000.
Now Gm loads with only the minor offset errors (0.008 etc).
17 Apr 2025 17:48 #326532 by electrosteam
Thanks for taking the interest.
Just realized that T1 at 0.000 is sensible.
It is the datum point against which the other tool offset heights are measured.
My previous post used the wrong terminology, not 'cutting length' but 'tip offset'.
I have an edge finder permanently mounted in a NT30 chuck.
I could set all my tool height offsets reference that.
Could be an ideal time to start using my table mounted tool height setter.
I never tripped over this in years of Axis use.
Always just touched-off the actual tool when it was mounted, never used the tool table.
When the mill is next in use, I will check how Axis handles this.
Moderators: newbynobi, HansU
Time to create page: 0.120 seconds
