Gmoccapy Modal Display
16 Apr 2025 04:50 #326428 by electrosteam
Gmoccapy Modal Display was created by electrosteam
Starting to use G54 and G55 to enable two job locations - new to me.
Test run a short program with G55 in the header.
In Axis, the Modal Display changes to G55 when a program is run, then back to G54 on completion.
In Gmoccapy, the Modal Display stays at G54, even though the DRO Display shows G55 while the program runs.
In each case, the DRO Display correctly shows the G55 Offsets and coordinates during the run time.
I think this must be a bug.
If so I can live with it.
23 Apr 2025 20:53 - 23 Apr 2025 20:53 #326980 by HansU
Replied by HansU on topic Gmoccapy Modal Display
The issue has been reported here: github.com/LinuxCNC/linuxcnc/issues/2753
Last edit: 23 Apr 2025 20:53 by HansU.
Moderators: newbynobi, HansU
Time to create page: 0.324 seconds
