GMOCCAPY 3.4.9 LCD7" can not display the whole GUI
20 May 2025 19:24 #328837 by foxlabs
Hello Guys,
I use a 7"LCD resolution 1024x600 for display the GUI can not display all ,especilly the height ,does anyone met this problem ,how to solve this problem?Thank you !
21 May 2025 03:58 #328852 by Aciera
If I am not mistaken then 600 vertical is not enough for the regular version, maybe this custom config for 800x600 helps:
github.com/LinuxCNC/linuxcnc/pull/2837
The following user(s) said Thank You: foxlabs
22 May 2025 20:40 - 22 May 2025 20:41 #328954 by foxlabs
Hello Aciera, Thank you for your replay , The orignal GMOCCAPY  I used on RPI4 is OK, but on RPI5 is not OK
Last edit: 22 May 2025 20:41 by foxlabs.
03 Jul 2025 01:47 #331145 by HansU
Can you post some screenshots to show the difference?
Moderators: newbynobi, HansU
Time to create page: 0.137 seconds
