versa-probe vs probe_screen_v2.9
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 May 2025 22:35 #329080 by zz912
versa-probe vs probe_screen_v2.9 was created by zz912
I dont have any experience with probe screen.
I don't know where to start. I found two sources:
1) Data in source codes:
lib/python/gladevcp/builtin-panels/versa-probe
github.com/LinuxCNC/linuxcnc/tree/master...n-panels/versa-probe
I don't know if it's possible to open it in Gmoccapy. And how?
2) Individual project:
github.com/verser-git/probe_screen_v2.9
What is better?
25 May 2025 07:53 #329093 by Aciera
Replied by Aciera on topic versa-probe vs probe_screen_v2.9
They are from the same author but 'versa-probe' has not seen any updates for a number of years.
If you are using 2.9 then you should probably use 'probe_screen_v2.9'
The following user(s) said Thank You: zz912
25 May 2025 16:24 #329117 by andypugh
Replied by andypugh on topic versa-probe vs probe_screen_v2.9
There is also "psng" and my own fork of psng here:
github.com/andypugh/probe-screen-ng
(My fork is adjusted for Gtk3 and Python3, but isn't currently working for me, I get no graphics in the tabs)
  • zz912
  • Platinum Member
  • Platinum Member
27 May 2025 11:28 #329211 by zz912
Replied by zz912 on topic versa-probe vs probe_screen_v2.9
What is the difference between your psng and lib/python/gladevcp/builtin-panels/versa-probe ?
Moderators: newbynobi, HansU
Time to create page: 0.080 seconds
