Tool setter in gmoccapy error.
- Sekai
09 Aug 2025 03:56 - 09 Aug 2025 03:58 #333099
by Sekai
Tool setter in gmoccapy error. was created by Sekai
Hi.I'm trying to put a automatic tool setter in my 3 axis cnc so i follow the instructions from: linuxcnc.org/docs/html/gui/gmoccapy.html...uto-tool-measurement
but it gives me and error when remap is activated.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/freza-mea'
Machine configuration file is 'freza-mea.ini'
INIFILE=/home/cnc/linuxcnc/configs/freza-mea/freza-mea.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./freza-mea.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
emc/task/emctask.cc 416: interp_error: File not open
File not open
emc/task/emctaskmain.cc 3091: can't initialize interpreter
A non blocked signal was caught
Debug file information:
NGC file not found: ngc=change - 51:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
/usr/bin/gmoccapy:312: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
/usr/bin/linuxcnc: line 896: 9599 Killed $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
9557
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 7626.194278] I-pipe: head domain RTAI registered.
[ 7626.194283] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 7626.194308] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7626.194311] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623640, CLK_FREQ 2926144000, CPU_FREQ 2926144000
[ 7626.194314] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7626.194316] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623640, 16623640, 16026250
[ 7626.200721] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7626.200747] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7626.200750] RTAI[sched]: hard timer type/freq = APIC/16623640(Hz); default timing: oneshot; linear timed lists.
[ 7626.200753] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2926144000 hz.
[ 7626.200755] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7626.204552] RTAI[math]: loaded.
[ 7626.339838] config string '0 out'
[ 7635.304394] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 7635.304396] This Message will only display once per session.
[ 7635.304397] Run the Latency Test and resolve before continuing.
[ 7648.985468] RTAI[math]: unloaded.
[ 7648.986662] SCHED releases registered named ALIEN PEDV$D
[ 7648.991033] RTAI[malloc]: unloaded.
[ 7649.088014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7649.089454] I-pipe: head domain RTAI unregistered.
[ 7649.089483] RTAI[hal]: unmounted.
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: joi 7 august 2025, 22:07:47 +0300
UTC Date: joi 7 august 2025, 19:07:47 +0000
this program: /usr/bin/linuxcnc_info
uptime: 22:07:47 up 2:07, 0 users, load average: 0,06, 0,10, 0,13
lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/freza-mea
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x1024 pixels (338x270 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/freza-mea/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
machine -m: i686
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=ce037f87-68af-43a0-8860-fcd14ee0c100 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
model name: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
cores: 2
cpu MHz: 2926.144
parport: 0378-037a : parport0
serial: 03f8-03ff : serial ec98-ec9f : serial
Versions:
gcc: gcc (Debian 4.7.2-5) 4.7.2
python: Python 2.7.3
git: git version 1.7.10.4
git commit: NA
tcl: 8.5
tk: 8.5
glade: not_in_PATH
glade-gtk2: glade3 3.8.0
linuxcnc_var all:
LINUXCNCVERSION: 2.8.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-3.4-9-rtai-686-pae/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Dorit=necUnoscut/Instalează/șteRge/curăță(P)/păstrează(H)
| Stare=Ne/Inst/fișCfg/desfăcUt/jum-conF/jum-inst(H)/așteaptă-decl(W)/decl-în-aștepT
|/ Ero?=(nimic)/Reinst-nec (St,Ero: majuscule=rău)
||/ Nume Versiune Architecture Descriere
ii linuxcnc 1:2.8.4 i386 motion controller for CNC machines and robots
un linuxcnc-doc <none> (nici o descriere disponibilă)
ii linuxcnc-doc-en 1:2.8.4 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> (nici o descriere disponibilă)
un linuxcnc-uspace <none> (nici o descriere disponibilă)
I still dont know to fix it.
the debian is wheezy.
thanks
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.4
VERSION=1.1
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Y Z
File not open
9557
pastebin.com
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: cnc
machine -m: i686
/proc items:
cores: 2
cpu MHz: 2926.144
Versions:
git commit: NA
tcl: 8.5
tk: 8.5
glade: not_in_PATH
linuxcnc_var all:
thanks
Last edit: 09 Aug 2025 03:58 by Sekai.
- zz912
- Thank you received: 98
09 Aug 2025 05:02 #333106
by zz912
Replied by zz912 on topic Tool setter in gmoccapy error.
The most important information is:
- Sekai
09 Aug 2025 05:06 #333107
by Sekai
Replied by Sekai on topic Tool setter in gmoccapy error.
i have the folder macros with change.ngc and on_abort.ngc
- zz912
09 Aug 2025 05:13 #333108
by zz912
In ini file is comented:
#SUBROUTINE_PATH = ./
Why?
Why?
- Sekai
09 Aug 2025 05:16 #333109
by Sekai
youre right.
I just looked at gmoccapy_tool_sensor.ini
and it should be like
SUBROUTINE_PATH = macros
the instructions website did not mention anything for subroutine path
Now it works.
Now it works.
Moderators: newbynobi, HansU
Time to create page: 0.172 seconds
