Gmoccapy tool setter install "errors"
- Fastfred
09 Oct 2025 18:27 #336169
by Fastfred
Gmoccapy tool setter install "errors" was created by Fastfred
Hi need some advice I tried to do this much as possible on my own but ran into a error not sure whats the best way to get around it.Looks like i have two pins for tool change ?
- Thank you received: 1476
09 Oct 2025 18:50 #336170
Replied by Todd Zuercher on topic Gmoccapy tool setter install "errors"
The problem is that you can not reuse a hal pin anywhere in that hal file or another hal file. However you can connect multiple hal input pins to a hal signal name (but only one hal output pin).
Not seeing what you have going on in your other hal files I think this might get you going change this line in your post gui hal file from:
to:
net tool-change-request iocontrol.0.tool-change
That may still not get your config working, if you have other similar mistakes in your postgui hal file. But it will get you on to the next one.
to:
- Fastfred
10 Oct 2025 19:26 #336213
by Fastfred
Replied by Fastfred on topic Gmoccapy tool setter install "errors"
Made the change net tool-change-request iocontrol.0.tool-change.
- Fastfred
10 Oct 2025 20:01 #336220
by Fastfred
[Gmoccapy.GMOCCAPY.GETINIINFO][[33mWARNING[0m] No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file (getiniinfo.py:282)
[Gmoccapy][[33mWARNING[0m] No virtual keyboard installed, we checked for <onboard>. Try 'sudo apt-get install onboard'. (gmoccapy:2112)
gmoccapy_postgui.hal:24: Pin 'gmoccapy.toolchange-change' was already linked to signal 'tool-change-request'
10530
10530
- Fastfred
10 Oct 2025 22:27 #336244
by Fastfred
This is after making a few changes trying to figure it out?
any help would be helpful
(gmoccapy:3126): Gtk-CRITICAL **: 15:22:03.887: gtk_entry_set_text: assertion 'text != NULL' failed
[Gmoccapy.GMOCCAPY.GETINIINFO][[33mWARNING[0m] Found kinstype=BOTH but using trivkins. It is not recommended to do so! Will use mode to switch between Joints and World mode, hopefully supported by the used <<trivkins>> module. (getiniinfo.py:182)
15:22:05.211 WARNING Config: mousetweaks GSettings schema not found, mousetweaks integration disabled.
/usr/lib/python3/dist-packages/gi/overrides/GObject.py:493: Warning: ../../../gobject/gsignal.c:2772: instance '0x15975de0' has no handler with id '33554454'
return func(*args, **kwargs)
3075
3075
- Thank you received: 2176
11 Oct 2025 10:03 #336272
Replied by Aciera on topic Gmoccapy tool setter install "errors"
This is from your 'gmoccapy_postgui.hal':
As has already been stated, you cannot reuse the same halpins use the signals they were assigned to.
Maybe this helps to explain some of the basics:
linuxcnc.org/docs/html/hal/intro.html
net tool-change-request => gmoccapy.toolchange-change
net tool-change-confirmed <= gmoccapy.toolchange-changed
net tool-number => gmoccapy.toolchange-number
net tool-changed gmoccapy.toolchange-changed => iocontrol.0.tool-changed
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
...As has already been stated, you cannot reuse the same halpins use the signals they were assigned to.
- Fastfred
11 Oct 2025 20:07 #336294
by Fastfred
Ok I got it , Guess I didn't pay attention just copied and paste Gmoccapy config to get it working not reading if I needed everything.
- Fastfred
11 Oct 2025 22:46 #336299
by Fastfred
Not Getting errors on start up, but a pop up saying file ended with no percent sign (%) or program end (M2)
- Fastfred
11 Oct 2025 22:49 #336300
by Fastfred
Forgot to say I got the error after asking for tool change in the GUI.
- Fastfred
12 Oct 2025 03:00 #336307
by Fastfred
I was able to figure out the end of line issue , but now not getting any movement after asking for tool change or pop up window?
Moderators: newbynobi, HansU
Time to create page: 0.157 seconds
