Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error?
- garulus
- Thank you received: 3
23 Nov 2025 12:45 #339071
by garulus
Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error? was created by garulus
I don't know if it belongs to here, but after fresh install Raspberry Pi 4/5 OS based on Debian Trixie, and initial setup I'm not able change tool offsets at all. Also work offset changes are displayed only after clicking off and back on "work offsets" page.
- zz912
- Thank you received: 98
23 Nov 2025 12:59 #339074
by zz912
Replied by zz912 on topic Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error?
Is it this bug?
github.com/LinuxCNC/linuxcnc/pull/3474
- garulus
23 Nov 2025 14:06 - 23 Nov 2025 15:36 #339087
by garulus
Replied by garulus on topic Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error?
Zdavim!
Doesn't seem so(I don't know). Switched from Raspberry PI to PC and Debian 12 Bookworm and I can edit tool offsets no problem.
Edit: Just tried previous version rpi-5-debian-bookworm-6.12.11-arm64-ext4-2025-01-27-0140.img.xz, and editing tools works!
Last edit: 23 Nov 2025 15:36 by garulus.
- unknown
- Thank you received: 323
23 Nov 2025 19:59 #339112
by unknown
Replied by unknown on topic Gmoccapy Raspberry Pi 4/5 OS based on Debian Trixie Tool Table Error?
It shouldn't be the OS it should be the version of Liunxcnc installed.
What happens if you upgrade the version of Linuxcnc on the current install. I only use axis.
Moderators: newbynobi, HansU
Time to create page: 1.098 seconds
