stepgen maxvel too big and MVO problem
30 Nov 2025 14:10 - 15 Dec 2025 05:04 #339489 by gravedigger
stepgen maxvel too big and MVO problem was created by gravedigger
  I have a problem with the stepgen: the max velocity is too high. Where and which value do I need to adjust? My steps with the Mesa 7i96 are 10,000 steps for the spindle.
The second problem concerns the MVO rotary encoder. The spindle and the normal feed work, but the rapid-feed encoder does not. Even when I swap the inputs for feed and spindle, it still doesn’t work. It seems to be an issue with the GUI/interface? Where can I start looking to solve this?
Last edit: 15 Dec 2025 05:04 by gravedigger.
30 Nov 2025 15:16 - 30 Nov 2025 15:23 #339496 by PCW
Replied by PCW on topic stepgen maxvel too big and SRO problem
The "Maxvel is to high" error means that the stepgen cannot physically generate
the  requested step rate with the current steplength and stepspace parameters.
Options are to:
Lower the steps per turn on the spindle drive
Lower the spindle maximum RPM
Lower the values of the step length and step space parameters
(as long as they still meet the drives minimum width specifications)
The maximum RPM will be 60/(steps per turn(step_length+step_space))
So for example at 10000 steps per turn and 5000 ns (.000005 seconds) for step length
and step space, the maximum RPM would be 600...
Last edit: 30 Nov 2025 15:23 by PCW.
30 Nov 2025 15:26 #339497 by zz912
Replied by zz912 on topic stepgen maxvel too big and SRO problem
You must degrease maxvel or you must degrease step timmings.
The second problem concerns the SRO rotary encoder. The spindle and the normal feed work, but the rapid-feed encoder does not. Even when I swap the inputs for feed and spindle, it still doesn’t work. It seems to be an issue with the GUI/interface? Where can I start looking to solve this?
We need more information. Specification encoder? Wiring encoder? What SRO mean?
30 Nov 2025 16:52 #339502 by gravedigger
Replied by gravedigger on topic stepgen maxvel too big and SRO problem
The encoder works on the spindle and for normal feed rates. However, if I switch the input in the Mesa software to rapid feed rate overlay, the bar does not move with the same encoder as for normal feed rates and the same wiring.
30 Nov 2025 16:55 #339504 by gravedigger
I don't actually need the rapid overlay. If I could operate rapid and normal feed with the same encoder, that would also be OK.
30 Nov 2025 17:55 #339511 by andypugh
Replied by andypugh on topic stepgen maxvel too big and SRO problem
The GUI's don't always "know" that you have changed an override.
Which GUI are you using? And how are you overriding (ie, which HAL pins are the counts going to?)
12 Dec 2025 18:31 #340009 by gravedigger
I tested with gmoccapy and dragon.
The MOV doesn't work. The spindle and the normal feed work with enc3.
# ---Überschreibung von Signalen zum Mesa-Geber - mpg (feed override signals to mesa encoder - mpg)---
net fo-count <= [HMOT](CARD0).7i73.0.0.enc1.count
# Vorschub-Override-Schritte verbinden - MPG (connect feed override increments - MPG)
setp halui.feed-override.direct-value false
setp halui.feed-override.scale .01
setp halui.feed-override.count-enable true
net fo-count => halui.feed-override.counts
# ---max Geschwindigkeit Neufestsetzungs-Signale an Mesa Encoder - mpg (max velocity override signals to mesa encoder - mpg)---
net mvo-count <= [HMOT](CARD0).7i73.0.0.enc3.count
# verbinde max Geschwindigkeit Neufestetzung Inkrement - MPG (connect max velocity override increments - MPG)
setp halui.max-velocity.direct-value false
setp halui.max-velocity.scale 0.666667
setp halui.max-velocity.count-enable true
net mvo-count => halui.max-velocity.counts
15 Dec 2025 04:57 #340112 by gravedigger
I was able to solve the error with maxvel too big by changing the steps per revolution to 2500 in the servo controller. Now I just have to solve the problem with the MVO.
Moderators: newbynobiHansU
Time to create page: 0.150 seconds
