Linuxcnc 2.9.x and Glade GTK3 display issue
18 Dec 2025 20:53 #340290 by mmt
Just upgraded to 2.9.x from 2.7.x i am in the process of recreating my glade window with gtk3. All worked good in 2.7.x and gtk2 but now with 2.9.x and gtk3 this code below in my ini file deletes the the box_vel_info but does not start the motion_control_test.ui
not sure what is going on. help is appreciated
EMBED_TAB_NAME = MOTION CONTROL
EMBED_TAB_LOCATION = box_vel_info
EMBED_TAB_COMMAND = gladevcp -x {XID} motion_control_test.ui
19 Dec 2025 06:00 #340298 by newbynobi
Replied by newbynobi on topic Linuxcnc 2.9.x and Glade GTK3 display issue
Please start linuxcnc from the command line and check the output there.
You will see there the error that does stop your panel to be embedded.
Norbert
19 Dec 2025 17:45 #340307 by mmt
thank you for reply
error says:
**** GLADE VCP ERROR: with xml file: motion_control_gtk3_.ui : gi.repository.Gtk' object has no attribute 'glade'
23 Dec 2025 14:01 #340419 by mmt
bump
23 Dec 2025 14:32 #340420 by Aciera
Replied by Aciera on topic Linuxcnc 2.9.x and Glade GTK3 display issue
might help to post your 'motion_control_test.ui'
23 Dec 2025 18:16 #340429 by mmt
Here you go
24 Dec 2025 12:53 #340461 by Aciera
Line 24, replace this:
<object class="GtkWindow">
with this:
<object class="GtkWindow" id="window1">
works for me on 2.10:
06 Jan 2026 17:48 #341080 by mmt
Sorry got distracted over the holidays.
So I made your recommended change to the glade file and it did not work. see screenshot
any more suggestions?
thank you as always
08 Jan 2026 21:54 - 09 Jan 2026 07:57 #341179 by HansU
Works for me as well with the change Aciera suggested.
Last edit: 09 Jan 2026 07:57 by HansU.
12 Jan 2026 16:56 #341315 by mmt
Im struggling to understand why it works for both of you. I have 2 different machines and a laptop and it works on none of them. All 3 computers running 2.9.3.
You changed nothing but line 24 ?
Moderators: newbynobi, HansU
Time to create page: 0.179 seconds
