How to setup a tool sensor
31 Dec 2025 13:31 #340795 by Thllll
How to setup a tool sensor was created by Thllll
How do you setup a tool sensor exactly? I cant seem get it right after a week of trial and error of setups, parameters changes. This is not a wiring issue or a debounce issue but a setup issue.
Current Setup:
LinuxCNC 2.9.4
2" tool sensor on the bed
Attached is my setup files
From this document  linuxcnc.org/docs/stable/html/gui/gmocca...uto-tool-measurement  I cant tell if I am doing something wrong or where the discrepancy is.
[TOOLSENSOR]
X = 10
Y = 10
Z = -20
MAXPROBE = -20
This example setup would cause the Z axis to come down to get to the -20 setpoint. This results in a crash into the probe and a "Probe tripped during a non-probe move" would appear. The solution to this was to set the Z to 0 so the probing search would start immediately
For this next issue is touch off x and y (not z because the document says to press "Block Height") I immediatly get a error when pressing x or y touch off.
"G-code error in change.ngc near line 76, file ended with no percent sign(5) or program end (m2)"
Now if I just ignore these errors I get the same error when doing a tool change after it probes it.
01 Jan 2026 16:18 #340861 by Thllll
Replied by Thllll on topic How to setup a tool sensor
Also its very odd that it throws an error for line 76 when the program ends at 72
Moderators: newbynobi, HansU
Time to create page: 0.211 seconds
