Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
- RotarySMP
- Thank you received: 595
02 Apr 2026 15:27 - 02 Apr 2026 23:49 #345077
by RotarySMP
Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie was created by RotarySMP
Hi Guys,
I updated my lathe to 2.9.8 on Trixie with Preemt-RT. Now Gmoccapy appears to have a bug causing it to scale up each time you exit the tool table or the max preview. window size setting also doesn't work correctly, as the screen reduces in height when commanded to increase in either width or height.
I made a video to show the behavior.
Like this, the lathe is nearly unusable, as I have to keep shutting down and restarting LinuxCNC to reset it. Any suggestions how to correct this greatly appreciated.
Cheers,
Mark
Cheers,
Mark
Last edit: 02 Apr 2026 23:49 by RotarySMP. Reason: Confused Preempt-RT and RTAI
- Online
- Thank you received: 7506
02 Apr 2026 15:54 #345082
This keeps reminding me of an American saying: never change a wining horse.
I am i am not helping.
Replied by tommylight on topic Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
I read that and thought "RTAI, resolution issues....", but nooo, you had to find something i have never seen, and it irrevocably seems a GmoccaPy issue.I updated my lathe to 2.9.8 on Trixie with RTAI.
- RotarySMP
02 Apr 2026 16:17 #345083
by RotarySMP
Replied by RotarySMP on topic Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
Yeah, you warned me.
After I tried to update 2.8.2 I screwed something up, and decided I may as well then pull the SSD and do a clean install.
If this is not easily fixible, I guess I could do a clean install of 2.8. and wheezy.
Cheers,
Mark
Cheers,
Mark
- Thank you received: 4155
02 Apr 2026 17:31 #345086
Replied by rodw on topic Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
RTAI? isn't your lathe using a Mesa card?
Why RTAI?
Why RTAI?
- RotarySMP
02 Apr 2026 23:48 - 02 Apr 2026 23:58 #345094
by RotarySMP
Oops, my bad, I wrote that from memory and got RTAI and Preempt-RT confused, Rod. It is Preempt-RT I have installed. I'll edit that in the original post.
Last edit: 02 Apr 2026 23:58 by RotarySMP.
- RotarySMP
03 Apr 2026 11:33 - 03 Apr 2026 11:43 #345111
by RotarySMP
Hans contacted over the github bug tracker, to have me run the Gmoccapy lathe sim, and sure enough, there is no scaling error behaviour there.
So I also tried the Gmoccapy Lathe_Macros sim, and that has the scaling behavior error.
When I created my current config, copied my old 2.8.2 config files, and cut paste the lathe macro files from this sim. Any ideas where I need to look for corrective action appreciated.
Cheers,
Mark
Cheers,
Mark
Last edit: 03 Apr 2026 11:43 by RotarySMP.
- RotarySMP
04 Apr 2026 02:25 - 04 Apr 2026 02:25 #345148
by RotarySMP
Hans got me sorted out. I had an error in my INI.
He had me replace:
with
EMBED_TAB_LOCATION = ntb_user_tabs
Now it has stopped scaling.
Big thanks to Hans for getting that straight.
Cheers,
Happy Mark
He had me replace:
with
Cheers,
Happy Mark
Last edit: 04 Apr 2026 02:25 by RotarySMP.
- HansU
- Thank you received: 217
04 Apr 2026 03:00 #345149
by HansU
Replied by HansU on topic Gmoccapy scaling up each time you exit tool table - 2.9.8 trixie
It's not really an error in your INI file. The lathemacro just needs too much space for some reason and in ntb_user_tabs is just more space available
- RotarySMP
04 Apr 2026 03:24 #345150
by RotarySMP
I just realised that the main Gmoccapy screen now behaves nicely. However, now I no longer have the tab for Andy's lathe macros.
- HansU
04 Apr 2026 05:14 #345153
by HansU
You still have it - it just moved to the user tab section.
Moderators: newbynobi, HansU
Time to create page: 0.329 seconds
