Launching gladevcp panel with gmoccapy
- Thank you received: 2177
21 May 2026 10:09 #346538
Replied by Aciera on topic Launching gladevcp panel with gmoccapy
As indicated in the 'Pins' list:
The correct pin name is
not just
crosshair_panel.crosshair-toggle-lednot just
crosshair-toggle-ledPlease Log in or Create an account to join the conversation.
- scsmith1451
- Thank you received: 3
21 May 2026 10:57 #346539
by scsmith1451
Replied by scsmith1451 on topic Launching gladevcp panel with gmoccapy
This is why we have code reviews. I frequently cannot see the forest for the trees.
Thank you!
Thank you!
- scsmith1451
09 Jun 2026 14:44 #347001
by scsmith1451
After much frustration, I finally have the gladevcp working with GMOCCAPY. All of the features I wanted to implement are working almost as expected.
At this point I find that when I activate the laser pointer from the gladevcp panel, then jogging is blocked regardless of which tab is currently active. It appears that when the toggle is active, it blocks all other functionality of LCNC. Once the toggle is deactivated, all features return to normal. Does anyone have insight regarding this issue?
Also, I googled how to close a floating vcp panel during shutdown and implementing a python handler for the GtkWidget "destroy" signal did not appear to work. Does anyone have an python example for implementation of the "destroy" signal in a gladevcp panel or have an example of how to close a vcp panel on shutdown?
Moderators: newbynobi, HansU
Time to create page: 0.079 seconds
