Can't read gcode text in dark mode when editing.
- TheTinkeringMechanic1
- Thank you received: 5
01 May 2026 20:14 #346089
by TheTinkeringMechanic1
Can't read gcode text in dark mode when editing. was created by TheTinkeringMechanic1
I'm having an issue that I couldn't find a solution that worked. I prefer Adwaita Dark theme. Everything is fine that is when I go to edit a gcode file in linuxcnc, the text highlight washes out the text. See image:
During my search I have found a script to add to the user command file, it just seems to crash when it tries to load. I have attempted to change the editor in the INI from gedit to mousepad, heck, I can actually leave it blank and it still changes nothing. I have changed the theme to use the system settings, still no change. The only way I can get this to where I can read the highlighted text is to change out of dark theme which isn't ideal. I'm sure there's a solution, I just haven't found one that works. Anyone else find a fix for this?
- Thank you received: 7506
01 May 2026 20:22 #346090
Replied by tommylight on topic Can't read gcode text in dark mode when editing.
1. that is not a LinuxCNC issue, so Debian forums are a much better place to ask
2. i had the same issue on Linux Mint when using the included dark themes, but 22.3 added new dark themes that fixed the issue.
3. you can try fine tuning colors for the dark theme, for text mainly as that worked on Mint so should also work on Debian.
01 May 2026 20:29 #346091
Replied by TheTinkeringMechanic1 on topic Can't read gcode text in dark mode when editing.
Changing any of the colors in Debian settings has no effect on the editor in linuxcnc. That's why I'm here.
01 May 2026 20:46 #346093
This is on Mint 22.3 with Mint-L-dark theme, notice the text on the left is clearly visible, on any other black theme no text can be seen there.
And this is not limited to LinuxCNC, many other programs i use daily had the same issue before so i had to revert to bright themes when using them.
What GUI are you using?
I know Axis can be modified, and so can the QT versions.
You can also try to install Mint themes in Debian, or Ubuntu themes. See also Ubuntu Studio as they do have some very nice themes, but forgot what they use as DE.
02 May 2026 11:17 #346100
System themes have no effect on the gcode editor in the linuxcnc program.
- HansU
- Thank you received: 217
02 May 2026 16:41 #346116
by HansU
Replied by HansU on topic Can't read gcode text in dark mode when editing.
We can only help you if you tell us which GUI do you use.
02 May 2026 17:33 - 02 May 2026 17:54 #346119
How do I tell what one it is?
Last edit: 02 May 2026 17:54 by TheTinkeringMechanic1.
- HansU
03 May 2026 04:24 #346130
by HansU
You could post your INI-file, a screenshot or whatever command you use to start your G-code editor.
03 May 2026 08:56 - 03 May 2026 09:40 #346135
Last edit: 03 May 2026 09:40 by TheTinkeringMechanic1.
- HansU
03 May 2026 12:21 #346140
by HansU
You probably run Gmoccapy 3.4.6.
I suggest to update LinuxCNC to the latest version, then you will find a new setting called "G-code theme" where you can select another theme for the G-code.
Moderators: newbynobi, HansU
Time to create page: 0.165 seconds
