can not jog axis in Gmoccapy
3 months 4 weeks ago #347484 by Etced
can not jog axis in Gmoccapy was created by Etced
After setting up axis , I go to the test axis button. There I can jog all axis and run the test program. When I go to Gmoccapy the cursor on the screen makes a line, but the motors do not turn. Any suggestions would be appreciated.
3 months 4 weeks ago #347486 by tommylight
Replied by tommylight on topic can not jog axis in Gmoccapy
What is pin "machine-is-enabled" connected to in hal?
3 months 4 weeks ago #347539 by Etced
Replied by Etced on topic can not jog axis in Gmoccapy
Since I am a linuxcnc newb I hope that the below pic is what you are asking for.
I have CL57Y drivers , currently they are wired to: PU+ PU- DR+ DR- . The MF+ (enabled +) and MF- (enabled -) are not connected.
If they do need to be connected do I connect them from MF+ to  the +5v and from MF- to GND on the TB2 terminal?
3 months 4 weeks ago #347546 by tommylight
NO, do not touch the wiring if it works with Axis GUI.
Upload the config files here so we can have a look, the working and non working ones.
The following user(s) said Thank You: Etced
3 months 3 weeks ago #347561 by Etced
I just noticed that in the PNC config wizard "test this axis" that I can jog xyz. However in the Step config wizard "test this axis" I can not jog xyz.
3 months 3 weeks ago #347562 by Etced
Step config files, where xyz jog does not work.
3 months 3 weeks ago #347600 by Etced
3 months 3 weeks ago #347602 by tommylight
This is confusing, why stepconfig?
Stepconfig is for parallel port setups, only.
3 months 3 weeks ago #347604 by Etced
Ok, that makes sense, I deleted the step config file. Currently I can jog XYZ in the pnc config "test this axis" .
Gmoccapy  jog does not work but shows movement on screen.
3 months 3 weeks ago #347624 by Aciera
Replied by Aciera on topic can not jog axis in Gmoccapy
You need to post the hal and ini files of the configuration that you are having the jogging issues with. Without those we are just poking around in the dark.
Moderators: newbynobi, HansU
Time to create page: 0.404 seconds
