can not jog axis in Gmoccapy
09 Jul 2026 13:37 #347630 by Etced
Replied by Etced on topic can not jog axis in Gmoccapy
Here are the Hal and ini files.
09 Jul 2026 14:52 #347633 by Aciera
Replied by Aciera on topic can not jog axis in Gmoccapy
1. ini file is missing
2. Take the config that uses AXIS gui (which apparently works), open the ini file and in the [DISPLAY] section change 'DISPLAY = axis' to 'DISPLAY = gmoccapy'. The config should now start with gmoccapy and jogging should work using the on screen jogging buttons.
3. Looking at the header in your hal file it seems that you are using a rather old prerelease of version 2.9 '# Using LinuxCNC version: Master (2.9)'
Unless there is a particular reason for this I would recommend using a more recent release (eg 2.9.10):
github.com/LinuxCNC/linuxcnc/releases#release-v2.9.10
The following user(s) said Thank You: Etced
10 Jul 2026 14:21 #347662 by Etced
I tried your suggestion of changing the "Display = gmoccapy", with no success.
Then I decided to update to v2.9.10 .
That did the trick, I changed "Display = gmoccapy" in axis. Now i can jog and home all axis in gmoccapy.
Thank you for your patience..
Moderators: newbynobiHansU
Time to create page: 0.159 seconds
