Highlighted gcode doesn't follow current position.
- TheTinkeringMechanic1
- Thank you received: 5
30 Jul 2026 15:52 #348219
by TheTinkeringMechanic1
Highlighted gcode doesn't follow current position. was created by TheTinkeringMechanic1
The is a minor thing that I hope is a simple fix.
The graphical display that follows the tool path is spot on with what the tool is doing. That's not a problem. What I noticed is the highlighted gcode shown isn't following the same position.
So if I tap a tool path line to highlight it in the grid of the graphic window it doesn't highlight that tool path in the gcode.
As you can see in the image I have the angled tool path highlighted which is supposed to be line 33, but in the gcode it's highlighting 29 which is the change in speed 5 lines prior.
A cursory search of the internet didn't reveal much other than recommendations to change g61,g64, but don't believe that has anything to do with this.
How do I correct this?
Thanks in advance.
Thanks in advance.
- Thank you received: 7492
30 Jul 2026 15:56 #348220
Replied by tommylight on topic Highlighted gcode doesn't follow current position.
What GUI?
30 Jul 2026 16:30 #348222
Replied by TheTinkeringMechanic1 on topic Highlighted gcode doesn't follow current position.
3.4.9
30 Jul 2026 16:57 #348223
What user interface on screen?
It seems like GmoccaPy.
Upload a picture of the whole screen.
That is most probably the kernel version, not the GUI.3.4.9
- Thank you received: 2177
30 Jul 2026 17:05 #348224
Replied by Aciera on topic Highlighted gcode doesn't follow current position.
Also, please post the gcode
30 Jul 2026 17:45 - 30 Jul 2026 17:49 #348227
Last edit: 30 Jul 2026 17:49 by TheTinkeringMechanic1.
30 Jul 2026 17:53 #348228
This is it.
30 Jul 2026 18:05 - 30 Jul 2026 18:07 #348229
Last edit: 30 Jul 2026 18:07 by TheTinkeringMechanic1. Reason: Update
30 Jul 2026 23:52 #348250
Yet you ask us for help.
You did neither, seems you are hiding something...Also, please post the gcode
30 Jul 2026 23:53 #348251
Thank you for reporting back.After posting that image of the g code I believe I see it now. The % symbol is on line 5. So that would explain everything being off set considering the line is starting at 1...
I knew it had to have been something silly.
Update: That was it....
Moderators: newbynobi, HansU
Time to create page: 1.296 seconds
