Highlighted gcode doesn't follow current position.
3 months 2 days ago #348219 by TheTinkeringMechanic1
The is a minor thing that I hope is a simple fix.
The graphical display that follows the tool path is spot on with what the tool is doing. That's not a problem. What I noticed is the highlighted gcode shown isn't following the same position.
So if I tap a tool path line to highlight it in the grid of the graphic window it doesn't highlight that tool path in the gcode.
As you can see in the image I have the angled tool path highlighted which is supposed to be line 33, but in the gcode it's highlighting 29 which is the change in speed 5 lines prior.
A cursory search of the internet didn't reveal much other than recommendations to change g61,g64, but don't believe that has anything to do with this.
How do I correct this?
Thanks in advance.
3 months 2 days ago #348220 by tommylight
3 months 2 days ago #348222 by TheTinkeringMechanic1
3 months 2 days ago #348223 by tommylight
3.4.9
That is most probably the kernel version, not the GUI.
What user interface on screen?
It seems like GmoccaPy.
Upload a picture of the whole screen.
3 months 2 days ago #348224 by Aciera
Also, please post the gcode
3 months 2 days ago - 3 months 2 days ago #348227 by TheTinkeringMechanic1
If this isn't the version,  I don't know where it would be.
Last edit: 3 months 2 days ago by TheTinkeringMechanic1.
Moderators: newbynobi, HansU
Time to create page: 0.323 seconds
