Parting
  • BigJohnT
  • Topic Author
  • Administrator
  • Administrator
13 years 2 months ago #38421 by BigJohnT
Parting was created by BigJohnT
This is my parting off subroutine for my lathe.
(info: Parting Off) o<part>sub #<OD> = #1 (Outside Dia) #<ID> = #2 (Inside Dia) #<ZPos> = #3 (Z Position) #<SFM> = #4 (SFM) #<IPM> = #5 (Feed IPM) #<MaxRPM> = #6 (Max RPM) #<Tool> = #7 (=5 Tool #) #<Coolant> = #8 (=8 Coolant) #<NextTool> = #9 (=1 Next Tool) G7 G18 G20 G40 G49 T#<Tool> M6 G43 G96 D#<MaxRPM> S#<SFM> M3 M#<Coolant> G0 X#<OD> Z#<ZPos> G1 X[#<ID> + -0.025] F#<IPM> G0 X#<OD> M5 M9 G53 G0 X0 Z0 T#<NextTool> M6 G43 o<part>endsub
JT
  • BigJohnT
  • Topic Author
  • Administrator
  • Administrator
10 years 1 month ago #80851 by BigJohnT
Replied by BigJohnT on topic Parting
I made a change to have the parting subroutine set my Z0 so I could cut off several parts before touching off. I set my parting blade so the right edge is at Z0.
(info: Parting Off) o<part>sub #<OD> = #1 (Outside Dia) #<ID> = #2 (Inside Dia) #<ZPos> = #3 (Z Position) #<SFM> = #4 (SFM) #<IPM> = #5 (Feed IPM) #<MaxRPM> = #6 (Max RPM) #<Tool> = #7 (=5 Tool #) #<Coolant> = #8 (=8 Coolant) #<NextTool> = #9 (=1 Next Tool) #<SetZ0> = #10 (=0 Set Z0 Yes 1) #<BladeWidth> = #11(Blade Width) G7 G18 G20 G40 G49 T#<Tool> M6 G43 G96 D#<MaxRPM> S#<SFM> M3 M#<Coolant> G0 X#<OD> Z#<ZPos> G1 X[#<ID> + -0.025] F#<IPM> G0 X#<OD> M5 M9 o100 if [#<SetZ0> EQ 1] G10 L20 P1 Z#<BladeWidth> (MSG,Z0 Set) o100 endif G53 G0 X0 Z0 T#<NextTool> M6 G43 o<part>endsub
JT
The following user(s) said Thank You: Rick G
Time to create page: 0.038 seconds
