Threading
5 years 3 weeks ago #222594 by 10K
Replied by 10K on topic Threading
Here's a minor tweak to the threading program that allows changing the allowance for the tightness of the fit (what Machenery's Handbook calls the class)
The following user(s) said Thank You: Dinuka_Shehan
5 years 3 weeks ago #222680 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Threading
5 years 3 weeks ago #222688 by 10K
And the nut fit the first time!
Glad you got the code working.
4 years 5 months ago #243678 by robertspark
Replied by robertspark on topic Threading
I have been fiddling around with some of these routines from this lathe section of the forum.
I added in the "tolerance" parameter for the metric threading macro.
I have also sorted out the order of the #vars as apparently with NGCGUI they need to be #1 #2 #3....#15 in numerical sequence. I notice that the "tolerance" in the original macros was out of sequence, so I've just resequenced both macros.
I've also added a bit of a check to find out what the current units you machine is set to at the start of running the macro and reset it back to those units at the end of the macro. The problem is not all of us use imperial machines .....
Check that the macros work for you and there are no errors as I've NOT run these on my machine yet, I was just doing a bit of a clean and tidy up on the general macros I downloaded to make them a bit more universal.
I also added a tool change in the sequence and coolant and also the rpm which was fixed as part of the macro.
Hopefully someone finds it of use / helpful.
you will need to rename them from txt to ngc
2 years 11 months ago #286589 by Carlos.crf1905
Replied by Carlos.crf1905 on topic Threading
alguem pode me ajudada o passo a passo,  onde coloco esses programas e como uso sou novo no linux cnc
2 years 5 months ago #301043 by COFHAL
Replied by COFHAL on topic Threading
Mañana le envio los archivos de ejemplo para usar los macros.
