Threading
7 years 2 weeks ago #148232 by 10K
Replied by 10K on topic Threading
Here's a metric threading routine
o<threading-metric> sub (metric threading subroutine) (threading-metric.ngc) (July 11, 2016 - M Kennedy) (Change these values) #<_MajorDiameter> = #1 (Major Diameter) #<_Pitch> = #2 (Pitch mm) #<_Z_Finish> = #3 (+/- Z Length mm, Z) (Don't usually have to change these values) (PeakOffset is initial tool clearance) #<_PeakOffset> = #4 (= -.1 Offset -ext, +int, I) #<_TipRadius> = #5 (= 0.005 Tip Radius) #<_Z_LeadIn> = #6 (= 2.5 Z Leadin) #<_Z_Final> = #7 (= 50 Z Final Position) #<_Spring_Passes> = #8 (= 1 Spring Passes, H) #<_First_Cut_Depth> = #9 (= 0.18 First Cut Depth, J) #<_Depth_Regression> = #10 (= 1.2 Depth Regression, R) #<_CompoundSlideAngle> = #11 (= 29.5 Angle, Q) #<_TaperAmount> = #12 (= 0 Taper) #<_TaperType> = #13 (= 0 Taper Type, L) (check to see if tool set) o100 if [#5400 EQ 0] (msg, Tool not set) M2 o100 endif (Calculations) (calculate ThreadDepth, K) o110 if [#<_PeakOffset> GT 0] (internal = pitch * cos30 * 2 * 6/8 - 2 * tip radius) #<_ThreadDepth>=[#<_Pitch> * 1.299 - 2 * #<_TipRadius>] (thread height = pitch * cos30 * 2 * 5/8) #<_MinorDiameter>=[#<_MajorDiameter> - #<_Pitch> * 1.0825] #<_Diameter>=[#<_MinorDiameter> - #<_PeakOffset>] o110 else (external = pitch * cos30 * 2 * 7/8 - 2 * tip radius) #<_ThreadDepth>=[#<_Pitch> * 1.5155 - 2 * #<_TipRadius>] #<_Diameter>=[#<_MajorDiameter> + #<_PeakOffset>] o110 endif G7 G18 G54 G90 G94 G21 (set metric units) G95 (feed per revolution mode) M3 F0 S500 (Go to OD and Z Lead in) G0 X#<_Diameter> Z#<_Z_LeadIn> (Thread) G76 P#<_Pitch> Z#<_Z_Finish> I#<_PeakOffset> J#<_First_Cut_Depth> R#<_Depth_Regression> K#<_ThreadDepth> Q#<_CompoundSlideAngle> H#<_Spring_Passes> L#<_TaperType> G00 X#<_Diameter> G00 Z#<_Z_Final> G20 (set standard units) M5 o<threading-metric> endsub
The following user(s) said Thank You: chimeno, nkp, tommylight, Dinuka_Shehan
7 years 1 week ago #148280 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Threading
It is complicated for change values.
O codes and hash tags confused me.
Can you please tell me how to create code with this.
Any examples
7 years 1 week ago #148328 by 10K
You don't have to change anything in the program. Link it to your GUI, and run it from there. I'm using the gmoccapy GUI. It'll bring up the parameters on an easy to change screen. Most of the info is OK as is. Input the thread size and pitch, and it'll generate the code automatically.
Here's the section of my .INI file that links this and several other o-code programs in:
# NGCGUI Entries # Note: TKPKG (one or more) specifies tcl/tk apps to embed in axis tab pages TKPKG = Ngcgui 1.0 NGCGUI_FONT = Helvetica -10 normal EMBED_TAB_NAME = NGCGUI EMBED_TAB_LOCATION = ntb_user_tabs EMBED_TAB_COMMAND = gladevcp -x {XID} ./pyngcgui_popupkeyboard.ui NGCGUI_PREAMBLE = lathe_std.ngc NGCGUI_SUBFILE = threading.ngc NGCGUI_SUBFILE = threading-metric.ngc NGCGUI_SUBFILE = npt_pipe.ngc NGCGUI_SUBFILE = turning.ngc NGCGUI_SUBFILE = taper-od.ngc NGCGUI_SUBFILE = facing.ngc NGCGUI_SUBFILE = knurling.ngc NGCGUI_OPTIONS = nonew noremove
The following user(s) said Thank You: chimeno, Clive S, Dinuka_Shehan
7 years 1 week ago #148444 by Dinuka_Shehan
10K wrote: You don't have to change anything in the program. Link it to your GUI
How to link with gui.
Steps or any guidance please!
7 years 1 week ago #148464 by 10K
Edit your .INI file. Here's my file, with the [DISPLAY] section that has some info for Gmoccapy. It points to the GUI and to the location of the o-code programs located in the directory shown under PROGRAM PREFIX. It also includes a list of the o-code programs.
[DISPLAY] DISPLAY = gmoccapy # DISPLAY = axis # DISPLAY = gscreen # DISPLAY = tkemc PROGRAM_PREFIX = ../../nc_files PREFERENCE_FILE_PATH = gmoccapy_preferences CYCLE_TIME = 150 # NGCGUI Entries # Note: TKPKG (one or more) specifies tcl/tk apps to embed in axis tab pages TKPKG = Ngcgui 1.0 NGCGUI_FONT = Helvetica -10 normal EMBED_TAB_NAME = NGCGUI EMBED_TAB_LOCATION = ntb_user_tabs EMBED_TAB_COMMAND = gladevcp -x {XID} ./pyngcgui_popupkeyboard.ui NGCGUI_PREAMBLE = lathe_std.ngc NGCGUI_SUBFILE = threading.ngc NGCGUI_SUBFILE = threading-metric.ngc NGCGUI_SUBFILE = npt_pipe.ngc NGCGUI_SUBFILE = turning.ngc NGCGUI_SUBFILE = taper-od.ngc NGCGUI_SUBFILE = facing.ngc NGCGUI_SUBFILE = knurling.ngc NGCGUI_OPTIONS = nonew noremove
The following user(s) said Thank You: Dinuka_Shehan
6 years 7 months ago - 6 years 7 months ago #159510 by Dinuka_Shehan
:dry:
Last edit: 6 years 7 months ago by Dinuka_Shehan.
Time to create page: 0.327 seconds
