Hello Fern,
I have been using NativeCam a lot these days and it is working out great for me with one exception and that is related to the Z depths in drill operations.
For example, I often use a drill cycle with a reamer. There is no option for a flat end drill or reamer. Using any other point option such as 118deg or 135 deg results in undesired and surprise Z depths of cut. If a option for flat bottom drills / reamers were added it would allow for these sort of operations with expected Z depths.
Another issue I have is spot drilling. Again, NativeCam must be using drill point angles and diameters to adjust Z depths. For example, with the spot drill set to .0001" in preferences, and a requested depth of .001 in the single hole routine, the Z actually goes to -.074 !! ( Z zero is set at top of stock) If spot drilling for a tiny number drill this produces a very bad surprise. I believe this is again because NativeCam calculates Z travel using drill dia, point angle and diameter and such along with the operators requested depth. I believe the same option of a flat bottom drill/reamer in the choices would allow the operator to reference off the drill point which would work nicely to get around this problem.
Any chance of adding a reamer/flat bottom option to the drill point angle selections? Or maybe you have a suggestion to work around these issues.
Thanks,
George
