- Thank you received: 3
NativeCAM is Features renamed
9 years 7 months ago #90660
by yeltrow
Replied by yeltrow on topic NativeCAM is Features renamed
FernV,
That type of script would work.
Can this control panel be run as a tab? I wasn't sure how I could come up with the -x option to pass loadusr if I did it myself. It seems like it is some magic random number.
Thanks!
Thanks!
9 years 7 months ago #90661
Replied by andypugh on topic NativeCAM is Features renamed
Does -x {XID} work?
9 years 7 months ago #90662
by FernV
Yes it can and this question was asked before in this thread and someone else have answered. I do not know how.
But if you have a wide monitor (available and inexpensive second hand),
you would be benefit in viewing the changes immediately.
The -x option is the address in memory of the parent for the new object (NCam in this case). This is passed by gladevcp, you do not have to worry about it
Fern
Replied by FernV on topic NativeCAM is Features renamed
yeltrow wrote: Can this control panel be run as a tab?
Fern
9 years 7 months ago - 9 years 7 months ago #90676
by roboylabs
Replied by roboylabs on topic NativeCAM is Features renamed
When i try to run NativeCAM i get this error.(Error Log is attached).. Pls help
Last edit: 9 years 7 months ago by roboylabs.
9 years 7 months ago #90698
by yeltrow
One additional clue that might be helpful in understanding the PYTHONPATH problem:
My workpiece shows as ENORMOUS and will not update. I haven't figured it out. It does it in the demo cofiguration too. I use inches. I also couldn't get a drill operation to execute. Milling seems to work as expected...
9 years 7 months ago #90699
by FernV
I updated nondeb_setup.py but I have to go without testing.
However I am sure it will do what it is suppose to do.
You only need this one to correct
I will be back at the end of the day
Fern
Fern
Time to create page: 0.080 seconds
