- Thank you received: 124
NativeCAM is Features renamed
grijalvap wrote: Hi
Do you know if there is any way to install nCAM, in the left side of the axis GUI, close to MDI?
thanks..
I never tried but if you look the 'GladeVCP command line options', maybe the -g could do it
Fern
- Thank you received: 1480
Do you know if there is any way to make this request to the AXIS designer?
thanks..
If you have your eye on the "blank" real estate on the left side of the Axis screen, much of that space is reserved for optional functions that only appear when those functions are configured, and it is space that just grows and opens up when Axis is used on a large screen (it was designed to work on the much smaller low resolution screens, common more than 10 years ago.)
So, basically the way to go is to migrate to Gmoccapy or other GUI?
gmouer wrote: I am loving NativeCam. I know it was mentioned that new additions are in the works. I have a request, could 4th rotary axis indexing be added? I am speaking of indexing only, not live 4th axis 3d cutting. I suppose it would need a preference to define if the rotary axis was A, C etc.
Hi George,
If you mill setup has A axis configured would you try this demo and tell me if it looks right ? The tool rotates but the path looks strange. Is it normal ?
You could also try with axis_9axis.ini
Fern
