- Thank you received: 75
FernV wrote:
gmouer wrote: I am loving NativeCam. I know it was mentioned that new additions are in the works. I have a request, could 4th rotary axis indexing be added? I am speaking of indexing only, not live 4th axis 3d cutting. I suppose it would need a preference to define if the rotary axis was A, C etc.
Hi George,
If you mill setup has A axis configured would you try this demo and tell me if it looks right ? The tool rotates but the path looks strange. Is it normal ?
You could also try with axis_9axis.ini
Fern
Do you really have to create an account just to clone ? Absolutely if you want to push data ...bogie6040 wrote: I cloned your GIT Repository...
Which to do so you need to create an account on github.com
Right, it is not mentionned but nondeb_setup.py will test if it is installed and mention in the terminal how to get it. However, I admit standalone will not run until done. Sorry for the inconvenience.bogie6040 wrote: The README.md no longer makes mention of the python-lxml prerequisite or the terminal command to install it, for those playing along at home it's: sudo apt-get install python-lxml
Though I have the sub-directory in my 'defaults' dir, it is still an empty directory and as such was not copied when I pushed to github.bogie6040 wrote: When I tried to run the command: linuxcnc inifilename per the README.md instructions linuxcnc opened up but there was no NativeCAM window on the right side of Axis and I got the following on the terminal after closing it:
OSError: [Errno 2] No such file or directory: '/home/bogie6040/linuxcnc/configs/NativeCAM/defaults/lathe'
So I went and looked in the NativeCAM/defaults folder and sure enough there was no lathe folder so I added it re-ran the command and then NativeCAM showed up.
Every time ncam starts it checks that files are up to date and it is trying to create a link that allready exists or a file with the same name. This part of the code create links to examples.bogie6040 wrote: ...after subsequent runs it stopped showing up and I get this:
File "/usr/lib/pymodules/python2.7/gladevcp/ncam.py", line 2033, in __init__
self.update_user_tree(fromdirs, NCAM_DIR)
File "/usr/lib/pymodules/python2.7/gladevcp/ncam.py", line 2203, in update_user_tree
os.symlink(srcdir, dst)
OSError: [Errno 17] File exists
