Trouble installing NativeCAM
- FernV
- Thank you received: 124
09 Jul 2017 13:11 #95537
by FernV
Fern
Replied by FernV on topic Trouble installing NativeCAM
Open some examples and see the order of the subroutines, Workpiece and ToolChange must ALWAYS be before a cut command....I keep getting the following error.
G-Code error in ncam.ngc
/home/steven/linuxcnc/configs/my-mill_4axis/ncam/scripts/ncam.ngc:
Named parameter #<_tool_usage> not defined
Fern
The following user(s) said Thank You: SteveT
- FernV
09 Jul 2017 13:13 #95538
by FernV
ncam -h
will give you the answer
Fern
...Would you mind giving me the command line to edit the launcher to be able to use Lathe instead of mill.
This is my Ncam working command line for Mill ncam -i /home/clive/linuxcnc/configs/baz_test/baz_test.ini
ncam -h
Fern
- Clive S
- Thank you received: 486
10 Jul 2017 11:56 #95589
by Clive S
Replied by Clive S on topic Trouble installing NativeCAM
Thanks for the rapid response
Time to create page: 0.226 seconds
