31659-nativecam-is-features examples
9 years 3 months ago #96012 by jmmontes
Hi Fern.
First of all thanks a lot for your great work with nativecam.
I have been trying to get familiarized with program preparing several plastic spacers for my mill steppers.
Could you please confirm basic spacer.xml included in nativecam 1.6 is a working example?
I have tried it in LINUXCNCVERSION=2.7.9-38-g140104a and blue progress bar freezes while loading clock does not disappear?
Thanks in advance.
José Miguel
9 years 3 months ago #96045 by FernV
jmmontes wrote: ...Could you please confirm basic spacer.xml included in nativecam 1.6 is a working example?
Hi José
I am running it with no problem in the simulator as I write this. Have you made any changes other than selecting a drill and cutter ?
Fern
9 years 3 months ago #96092 by jmmontes
Hi Fern,
I have not even selected drill or cutter.
I copy output when launching lcnc with axis_mm simulator.
Quote.
Machine configuration file is 'axis_mm.ini'
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
task: main loop took 0.013569 seconds
task: main loop took 0.013592 seconds
gladevcp: auxiliary dir: /usr/share/linuxcnc/aux_gladevcp/NativeCAM
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
gladevcp: importing: /usr/share/linuxcnc/aux_gladevcp/NativeCAM/pref_edit.py
NativeCAM info:
inifile = /home/jm/linuxcnc/configs/sim.axis-1/axis_mm.ini
NCAM_DIR = /home/jm/linuxcnc/configs/sim.axis-1/ncam
SYS_DIR = /usr/share/linuxcnc/aux_gladevcp/NativeCAM
program = /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py
[RS274NGC]SUBROUTINE_PATH = ncam/my-stuff:ncam/lib/mill:ncam/lib/utilities
Real paths:
/home/jm/linuxcnc/configs/sim.axis-1/ncam/my-stuff
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/mill
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/lib/utilities
Using default mill/menu.xml, no mill/menu-custom.xml found
/usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.py:2327: GtkWarning: IA__gtk_accel_label_set_accel_closure: assertion `gtk_accel_group_from_accel_closure (accel_closure) != NULL' failed
mi = _action.create_menu_item()
Previous work not saved as current work
task: main loop took 0.013271 seconds
task: main loop took 0.014709 seconds
Xlib.protocol.request.QueryExtension
task: main loop took 0.010065 seconds
task: main loop took 0.013747 seconds
task: main loop took 0.013752 seconds
Drill info : diameter = 6.350000, point angle = 118 &0.000000;, point length = 1.907732
task: main loop took 0.011907 seconds
task: main loop took 0.012652 seconds
task: main loop took 0.010047 seconds
Unquote.
For your information wheel demo.xml opens without any error.
José Miguel
file:///home/jm/linuxcnc/configs/sim.axis-1/axis_mm.ini
9 years 3 months ago #96093 by FernV
José
Load the example, read the comment then select Params and read last line
Fern
9 years 3 months ago #96096 by jmmontes
Hi Fern,
Example does not open, screen stays as in attached screenshoot, I have to force closing lcnc.
José Miguel
9 years 3 months ago #96099 by FernV
José,
  1. Restart lcnc.
  2. Uncheck Auto-refresh from NativeCAM Utilities menu
  3. Open 'basic spacer.xml' example
  4. Change values in Params for some metric ones
  5. Click on the Build Button (the one that looks like a gear)
If this does not work, post ALL screen shots that you think are pertinent
Fern
Time to create page: 0.312 seconds
