31659-nativecam-is-features examples
9 years 3 months ago #96144 by FernV
Hi José
I have an update for 'basic spacer.xml' here not published yet.
File Name: basicspacer.xml
File Size:59.97 KB
Would you save it in '/home/jm/linuxcnc/configs/sim.axis-1/ncam/catalogs/mill/projects' and see if it works for you
If not you have some other issues
Fern
9 years 3 months ago #96155 by jmmontes
Hi again Fern,
Thanks again for your proactivity.
I attach g-code error.
Before asking for your support, I uninstalled ncam, deleted ncam directory in /home/jm and all ncam folders inside /home/jm/linuxcnc/configs, then Installed ncam 1.6 by means of apt-get install.
Take also into account that now my version is linuxcnc 2,7.10 due to last update.
José Miguel
9 years 3 months ago #96160 by FernV
Hi José
You are not giving me much stuff to help you solve your issue. I think it is something you have not configured well but I need to see more.
I see you are using nativecan stand alone.
I want to see ncam.ngc, the output of the terminal when you run it, the directory and sub-directories content where your inifile is.
I guess you have executed $ ncam -i inifile -c mill -t
because I saw that ncam is in a tab.
Give me everything, so I can help
Fern
9 years 3 months ago #96231 by FernV
Time to create page: 0.050 seconds
