NativeCAM features request
- eFalegname
- Thank you received: 30
06 Feb 2018 10:16 - 22 Jul 2018 14:40 #105483
by eFalegname
NativeCAM features request was created by eFalegname
Hi Fern,
I'm using NativeCAM every day, mostly to transform, mix and manipulate my gcode, and as project organizer-management tool, unfortunately I still can't do all my gcode files without "windowscadcam" for this reason I opened this post, to organize the ideas about the features and improvements that I would like to see on NativeCAM to make from it my primary CAM.
F-engrave is installed along LinuxCNC, can I suggest a feature to make V-Carving and V-Inlay like the F-engrave program does? These are very used processes, besides with F-engrave it is possible to import .dxf and bitmaps to engrave.
github.com/stephenhouser/f-engrave
With G-code ripper is possible Scale, Split and Wrap G-Code even on irregular surfaces using the autoprobe function.
www.scorchworks.com/Gcoderipper/gcoderipper.html
For what I understand these two programs are python scripts, maybe it would be possible to use NativeCam as frontend as done before with ttrace to engraving text...
Thanks a lot for your great work and please, keep my dream alive
Cheers
Floris
Cheers
Floris
Last edit: 22 Jul 2018 14:40 by eFalegname.
- FernV
- Thank you received: 124
06 Feb 2018 14:39 #105492
by FernV
Replied by FernV on topic NativeCAM features request
Hi Floris
I do not know those apps...
I will have to take a good look at them and put on my enhancement list if possible for later development
Fern
Fern
- Thank you received: 7488
28 Mar 2018 00:22 #108015
Replied by tommylight on topic NativeCAM features request
I am assuming we can use this thread for other requests for added features to NCAM, so i have one i would like to add:
Rotary plasma tube/profile cutter
I am in the process of building a prototype like the professional ones on youtube, but it is going slowly due to to much projects i am working on. Of course the build log will be posted on the forum.
The following user(s) said Thank You: FernV
- FernV
07 Nov 2018 20:55 #120204
by FernV
Hi Floris,
I was out of country a good while for the last 6 months and I could not work much on the project. Next version will be 2.0
Not much improvements in the interface but much better g-code.
Meanwhile, if you have new requests please post them
Regards
Fern
Regards
Fern
The following user(s) said Thank You: skench, tommylight, pommen
- freemoore
- Thank you received: 15
10 Aug 2019 09:48 #141859
by freemoore
Replied by freemoore on topic NativeCAM features request
Hi all. I finally got a plasma table working with Tommylight's latest config (2.8pre stepper version), and also NativeCam installed on the same machine with the plasma catalog installed.
My problem is that the plasma won't run gcode generated by ncam. If I hand-code a simple thing with M3/M5 this works OK (and the THC works at last, thank you Tom!).
Ncam program is shown in the Axis gui preview window OK; but when I press run the machine just sits there waiting. I know toma_thc needs M3/M5 to fire the torch - I can't find any preference setting in Ncam to pick a spindle/torch command, I can't see any M3/M5 in the gcode window of ncam's output.
How can I get Ncam working with the toma_thc plasma?
10 Aug 2019 10:05 #141860
You are welcomed.
I can not think of anything that would inhibit the functionality of Linuxcnc, although i do remember back when ncam was released i had the same problem.
13 Aug 2019 17:55 #142057
Replied by andypugh on topic NativeCAM features request
Doesn't NCAM do something clever with block delete? It might also insert optional pauses.
Try toggling those extra buttons in the GUI that you never otherwise use
- Roguish
- Thank you received: 31
23 Aug 2019 20:24 #143005
by Roguish
Replied by Roguish on topic NativeCAM features request
I've been using NativeCAM a while now. Very Handy.
One request, though. How about adding some code to return the part/tool to their positions at the start of a routine?
I usually start a few inches away from my part, for safety and convenience. When a NativeCAM routine completes, the tools end up in a fairly arbitrary position above the part.
Sure would be nice to just return, safely, to the point it started from.....
Just asking.....
Thanks for the Linuxcnc plugin, addon, extension, or whatever it's called.......
Just asking.....
Time to create page: 0.129 seconds
